Results 1 to 8 of 8
Thread: Wanted, pre facelift front euro bumper
    May 2013
    Killingworth, CT
    '84 733i, 01 X5 00 750iL
    I am looking for a good condition pre facelift front euro bumper (and brackets if you have them). I am considering using a pre facelift bumper on my 1984 US 733i instead of the facelift euro 745i front bumper I already have so that I don't have a huge euro license plate frame with a US plate. I am not planning on running a vanity euro front plate and don't like how a US plate is going to look in the frame that is built into the facelift euro bumper.
    A pre facelift bumper will fit my facelift car, right? Thanks, Steve
    Steve H.
    May 2014
    California
    84 733, 90 535i
    I have the same US model; I have a full euro pre facelift on it. I personally had to make a notch on the headlight housing for the pieces that look like this |_| towards the corner of headlight housing close towards fenders. You may or may not have to. Hope this helps.
    I am curious to view what you mean on your 745i euro front, so a picture would be appreciated
    May 2013
    Killingworth, CT
    I don't have a photo. The facelift euro front bumper off my 745i donor car has the license plate mount molded into the air dam. If you mount a US license plate in the space allotted you have big gaps on the sides. I do not want to run a euro vanity plate on the front of this car to fill in the space like many people do. I noticed that the pre facelift euro bumper does not have this molded in license plate mount.
    My other option is find a good BBS air dam, which also lack the license plate mount.
    Steve H.
    May 2014
    California
    84 733, 90 535i
    No problem, I looked into one and see what you mean. Ugly US square cut out.
    Also what sizings are the M Parallel on your e23 and are you using any spacers at all?
    May 2013
    Killingworth, CT
    These are E38 wheels so 18x8 front 18x9.5 rear IIRC. No spacers. The rear could use a ~10 mm spacer, with a 265/35 it just barely rubs the inner wheel house edge. I am waiting on spacers I just bought. 10mm hub centric spacers that I initially test fit on the rear do not quite clear the 11-12mm long rear hub register so they would not sit flat against the rotor. I just ordered a pair of 12mm hub centric spacers and longer wheel bolts which should clear the hub. I have a set of Dinan coils going on this car and I'm also upping the rear tire size to 275/35 so I need to make sure i have enough room inboard. Outboard there is plenty of room.
    Steve H.
    May 2010
    Tangent Oregon
    79' 320i 84' 733i
    For what it's worth, I took the euro bumpers off an '82 pre-facelift grey market car and installed them on my '84 733i US car without having to cut or modify anything in the front.
    May 2013
    Killingworth, CT
    Thank you Steven! That is what I needed to know. I suspected they would work but it's good to know for sure.
    Steve H.
    May 2014
    California
    84 733, 90 535i
  1. Pre-Facelift Front Bumper Impact Strip
    By TMBMax in forum 1995 - 2001 (E38)
    Last Post: 01-13-2016, 02:54 AM
  2. E39 WTB: E39 Pre-FaceLift Front Bumper Lip
    By AlpinaWannaBe in forum BMW Parts Wanted
    Last Post: 12-17-2009, 11:28 PM
  3. Front Euro-Bumper Conversion (Keith?)
    By WTA123 in forum 2002
    Last Post: 05-05-2005, 09:50 PM
  4. Front Euro bumper bracket removal???
    By Al Canuck in forum 1975 - 1983 (E21)
    Last Post: 02-20-2005, 09:12 PM
  5. Front Euro bumper up on ebay (link)
    By MattE21 in forum 1975 - 1983 (E21)
    Last Post: 08-27-2003, 04:25 PM
