Results 1 to 14 of 14
Thread: A/C & Auxiliary Fan Diagnosis Verification Please!
    Feb 2015
    Kuna, Idaho
    Too Many Cars (NOT!)
    Question A/C & Auxiliary Fan Diagnosis Verification Please!
    The car: 1997 528i - 05/29/96
    The problem: Auxiliary fan does not turn on when A/C is engaged.
    Replaced auxiliary fan due to broken blades and non-op of original with Hella/Behr. Replaced two stage temperature switch with BMW.
    When engaging A/C, compressor clutch engages and A/C blows cold air, however auxiliary fan does not operate.
    Fuses checked good. Have not checked relays.
    Questions:
    Does the engine have to be at normal operating temp for the auxiliary fan to kick on with the A/C?
    Does the external air temp sensor have any effect on auxiliary fan operation?
    Can anyone shed some light on the external air temp sensor installation location? I found it hanging under the car and since having the whole front end off, I cannot locate a bung or hole or anything that it fits into. On my 850, it fits into one of the brake ducts (if I remember correctly). Can't find anywhere for it to fit in.
    Could I have a bad control unit in the dash? It does act a bit squirrely. When engaging the A/C, if the fan speed is on low, it will increase it to 1/2 way up.
    I'm kind of running out of ideas. All help and suggestions would be greatly appreciated.
    Thank you,
    Mike
    Mike Drives:
    BMW's
    E24 - 635CSiA - (1) 1985 (US)
    E24 - 635CSi - (1) 1985 (EC)
    E31 - 850iA - (1) 1991 (Black)
    E31 - 850iA - (1) 1991 (Calypso Red)
    E32 - 740iA - (1) 1994
    E32 - 750iA - (1) 1990 (Not an "L") (EC German National)
    E32 - 735iL - (2) 1990
    E32 - 750iL - (1) 1990
    E38 - 740iLA - (2) (1) 1997 & (1) 1998
    E38 - 750iLA - (1) 1998
    E38 - 740iA - (1) 2000 "Short Sport"
    E39 - 528iA - (2) - 2000 & (1) 1997
    Also:
    2015 Ram 3500 Dually, Cumins 6.7, Std.Cab. Long box 4x4 (To haul all this junk when necessary)
    2014 Dodge Dart Rallye (Daily Driver)
    2007 Mercedes Benz CL600 (Brabus SV12S)
    Mercedes Benz SL's - (1) (2002) & (1) 1999 500 - (1) 1999 600
    1967 Buick Riviera (2)
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Your 97 should have resistors in the fan circuit for low and medium speed control. They are know to burn out so the fan won't operate on those two speeds. The resistors are mounted on the aux fan frame.
    Your temp sensor under the bumper has nothing to do with the Aux fan not working.
    San Jose, CA
    1997 BMW 540i 6 speed
    If the temp on the cluster reads -40 deg, the side mirrors will eventually cook and become opaque.
    The ext temp sensor fits into the bottom of the plastic finisher at the lower right side of the front bumper. Sounds like yours is missing, not uncommon, esp when striking curbs and such.
    This video is for the E46. The E39 sensor is mounted to the right side. Otherwise, the procedure is similar
    https://www.youtube.com/watch?v=RrgeWWZ4dnk
    This link shows how to cobber up a different mounting:
    http://bimmerboard.com/forums/posts/181335/
    This is a reason to replace the sensor.
    https://www.bimmerforums.com/forum/s...erature-Sensor
    Here is the resistor assembly noted by Jim, item 8: https://www.realoem.com/bmw/enUS/sho...diagId=64_0832
    Feb 2015
    Kuna, Idaho
    Gentlemen, thank you for the prompt response.
    I probably failed to mention that the new auxiliary fan came with all new resistors as well, so short version - fan, resistors and fan 2 stage temp switch are all new. Fuses checked - all good.
    The A/C does operate normally, however the auxiliary fan does not operate at all.
    I must be missing something, but for the life of me, I don't know what.
    Mike Drives:
    BMW's
    Also:
    San Jose, CA
    The relay(s) may have failed.
    There are three, but the suspicious one is K21, which controls the normal speed. It's in the E-box, the one closest to the right side of the E-box.
    May 2018
    LT - EU
    E39 530D
    Have you checked fuse near battery?
    There's 100A fuse (or 110????) in the back near battery. It's in that white box where you need to remove cover to see fuses.
    I had same problem and couldn't figure it out, because that fuse isn't called fan fuse or something like that. It's called "fuse for fuse box number something". It's a fuse for those 2 fuses under the glove box.
    Well at least it's like that on my 530d. Maybe it's like that on diesel engines. In my case glow plug relay and fan wasn't working.
    Feb 2015
    Kuna, Idaho
    Checked the fuse in the box in trunk by the battery. All are good (tested with meter). So I guess it's relay time.
    I'll update after that.
    Thanks again,
    Mike
    Mike Drives:
    BMW's
    Also:
    Feb 2015
    Kuna, Idaho
    Update;
    I, apparently am too clueless to work on these things. I finally discovered fuse 7 was missing. Put a fuse in, have 12v to 30 & 87 in the relay socket. Plugged the relay back in, started the engine, hit the a/c button - blew 7.
    Is there a somewhat common place for a short (I'm assuming a short)?
    Electrical is not my strongest suit.
    Thank you
    Mike Drives:
    BMW's
    Also:
    San Jose, CA
    Is this a new relay? If so, sounds like there is a wiring fault.
    Feb 2015
    Kuna, Idaho
    Yes, I did install a new relay, so I guess I have to try and find a short or whatever is causing fuse 7 to blow.
    Is there a possibility the HVAC control is causing this problem. It's a little hinky in that when I change the temp, the fan speed increases whether I change the temp up or down. It's weird.
    Thanks for all your help,
    Mike
    Mike Drives:
    BMW's
    Also:
    JimLev's Avatar
    Sundance Mesa, NM
    F7 (20A) feed power thru the relay (K21) contacts and then to one end of the resistor on the fan frame for the low speed.
    Pull the relay and see if the fuse still blows, that will tell you which side of the relay the short is on.
    Feb 2015
    Kuna, Idaho
    Jim;
    Did as you suggested. Fuse 7 did not blow. Does this mean the short is on the load side of the relay?
    Thanks,
    Mike
    Mike Drives:
    BMW's
    Also:
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by masbury View Post
    Jim;
    Thanks,
    Mike
    Yes, either the wire from the relay to the fan frame is pinched or it could be shorted to the chassis where the wire connects to the resistor.
    Feb 2015
    Kuna, Idaho
    Thanks, Jim. At least I have a starting point. If you think too long about how much wiring there is in these cars, you get somewhat overwhelmed.
    Appreciate it,
    Mike
    Mike Drives:
    BMW's
    Also:
  1. Auxiliary fan diagnosis
    By shenofjo in forum 1995 - 2001 (E38)
    Last Post: 08-02-2015, 01:19 AM
  2. Need Help With Auxiliary Fan Diagnosis
    By PSURT in forum 1992 - 1999 M3 (E36)
    Last Post: 03-11-2014, 10:11 PM
  3. Auxiliary Fan Assembly 09/1998-2003 Part Verification
    By blahness in forum 1996 - 2003 (E39)
    Last Post: 01-10-2012, 11:49 PM
  4. issue with Auxiliary Fans! please help
    By bdpride04 in forum 1996 - 2003 (E39)
    Last Post: 05-17-2009, 09:46 PM
  5. Auxiliary fan problems Please Help!!! 98 540i
    By betep in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-08-2005, 06:51 PM
