Results 1 to 6 of 6
Thread: Rebuilt electronics advise for E23
    Sep 2017
    Grand Rapids, Mi, kent
    08 E63, 87 E23
    Anybody have any experience with ProgramInc on reman electronics. Looking for the HVAC pushbuttons and thumb-wheel, has ACC.
    Thanks.
    Jun 2010
    TX
    1983/84/85 745i
    Programma is junk. PM me and I will give you contact details for Kris Rose.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Quadratechtown, PA
    5, 7, 4x4
    or if you DIY, www.e38.org/e23, lots of projects and the switch rebuilds are there.
    Sep 2017
    08 E63, 87 E23
    I would give it a try, saw the microswitch replacement but the symptoms do not match. I have not been able to determine the fault so in spite of my reluctance to start throwing parts at it, this is where I'm at. To summarize, heat blows whenever the blower fan is on no matter where the temp thumbwheel is set. I checked voltage to the heater control valve vacuum selenoid, and sure nough, it looses voltage when I turn the blower fan thumbwheel on any speed, and then it opens the heater control valve. Again, no matter what temp the temp thumbwheel is on. I also tried warming up the inside temp sensor, no change.
    Quadratechtown, PA
    5, 7, 4x4
    This system runs on vacuum. Might be a vacuum leak at the reservoir T under the cowl passenger's side.
    Sep 2017
    08 E63, 87 E23
    I put a vacuum on the entire vacuum circuit with the engine off and it goes right up to 15 and holds it, the control valve also holds a vacuum as well. It is the loss of voltage to the control valve vacuum selenoid that causes heat control valve to open and allow hot water to enter the heater box. None the less, I've read enough to know those plastic tee's are out, so great point on that. I live in Michigan, and whether it has an effect or not, all my lines and that kind of stuff doesn't dry out like it would in a arid climate like Arizona or similar. One other thing I just thought of. There is a vacuum check valve in the vac line going from the plenum to that emissions vapor diaphram thing on the intake bellow. The big line from that diaphram goes to the charcoal filter I beieve. Anyway, that check valve prevents engine vacuum from getting to that diaphram, ie. the check valve checks that vacuum cannot travel into the plenum. That seems odd.
  1. Removing electronic rear seats - E23
    By GazM3 in forum 1978 - 1987 (E23)
    Last Post: 05-15-2016, 04:21 PM
  2. very wierd, damn weather messed up my cars electronics e23
    By THEhomelessONE in forum 1978 - 1987 (E23)
    Last Post: 01-06-2008, 07:05 PM
  3. How to make led dimmable. Need some advise from electronic gurus.
    By M3motorsport in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-13-2006, 10:29 AM
  4. How to make led dimmable. Need some advise from electronic gurus.
    By M3motorsport in forum 1991 - 1999 (E36)
    Last Post: 03-11-2006, 11:09 PM
  5. Rebuilt abs pump from Auto and Truck Electronics
    By rocket808 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-25-2005, 08:42 PM
