M5X/E34 T3 Tubular Turbo Manifold
Howdy,
I bought this manifold used from someone else that had it running on their E34 build. I mounted it up, but it got too close to the A/C condenser for me to use it. If you're not running A/C and are building a turbo E34, this would be perfect.
I haven't found any cracks or holes and it mounted up to the motor just fine. I can include the 44mm wastegate vband adapter if needed. Price is $325 shipped or local pickup in Minneapolis minus shipping.
Sent from my Nexus 6P using Tapatalk
'95 E34 525i, M50B32 (S52 Crank, K1 Rods, JE 9.0:1 Pistons, S52 Cams, Cutring, Achilles Oil Pump Shaft & Sprocket), GTW3684R 0.82A/R, ZF320
