Results 1 to 16 of 16
Thread: E32 Technology and Diagnostics video (German)
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    A YouTube user uploaded a neat video two days ago about the E32. It shows some technical details and design elements, but I can't understand it. Maybe YouTube's auto-translate can help
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Excellent, very nice, German language is no problem for me. Even if you do not understand German, it is worth to watch all 29.21 minutes, explains the complete system, where which control units are etc
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    Please let us know if you learn something cool from the video, Shogun.
    Jan 2005
    Japan
    is also good as DIY training video, how to remove bumpers, where all the relays and modules are, for example I will use this youtube now if someone is asking where the transmission control unit is located.
    How to remove the trunk lid they also show, but that I found out from another brochure already more 12 years ago, here the picks how to make out of your E32 a pick up in a few minutes http://www.bimmerboard.com/forums/posts/170639/
    Also nice the demonstration of the fuel injectors in normal operation and emergency. Our engine has what they call semi sequential fuel injection, meaning that the injectors normally open in 2 groups of 3.... 1,3,5 open then 2.4.6 open the next revolution. This is done to control injection a little more precisely for emissions. It uses this induction loop as the sensor to determine where it is in the firing order. When it fails it goes into a mode where all the injectors open simultaneously but they only stay open for half as long since this way they open every revolution. This doesn't measure fuel quite as precisely but most people haven't been able to tell any difference in how it runs.
    If the inductive sensor on the plug wire fails then it goes into gang firing (as I call it), since the m30 is a semi sequential design meaning that it triggers the injectors in 2 banks of 3 every other revolution, when it goes into the gang fire, then it triggers all six at the same time every revolution but decreases the volume of fuel by 50% ..
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    Cool stuff. I did watch it all, the visuals are enough often times. It's quite awesome to see such a perfect E32 in video, no rock chips or anything
    I want one of those showroom plates on my 735iL. Finding a part number would be tricky.
    Jan 2005
    Japan
    Part 2 , SMM Memory, Softclose Tueren + Kofferraum, Zentralverriegelung, Abblendbarer Innenspiegel, Standheizung/Klima, elektr. Heckrollo, Rollos fuer die Seitenscheiben, Zentralverriegelung ZKE, 25 Minutes
    Neues aus der Teiletechnik Teil 2 https://www.youtube.com/watch?v=x82u6hXcXPg
    Jul 2015
    Montreal, QC, Canada
    09/87 E32 750iL
    Quote Originally Posted by shogun View Post
    Translation: seat and mirror memory, softclose doors + trunk, central locking, dippable rear view mirror, auxiliary heating and air conditioning, electrical blinds on rear window, blinds on rear side windows, central locking ZKE (Zentrale Karosserie Elektronik = central body electronics)
    This is Part II of a training video for the parts departments at dealerships.
    warwick RI
    E30/E32/F25
    They had soft close doors in the e32?!? I’ve only seen the soft close trunk
    Me E30 87/ 325i + F25 12/ M-Sport + E32 94/ 740i
    G/F’s E34 92/ 525iT + F48 18/ X1
    Jan 2005
    Japan
    We discussed that since years from 2009 on the German 7-forum, no one has ever seen them, it is even mentioned in some owners manuals and even in a workshop manual and a brochure, but always with the note "under preparation".
    http://www.7-forum.com/forum/showthr...t=119063&page=
    Last year I disassembled a crashed 750iL from 1993-11-12 that even hat in the fuse box the sticker for the fuses : 56,57 Automatic "Soft-close" system !
    But I could not find them, also the door lock system was not different. We came to the conclusion that no E32 has it, was under preparation, but never realized and only came into the E38.
    warwick RI
    E30/E32/F25
    I’ve never seen them in e38 either, only e66/65. e38 had the soft close trunk standard in USA. In euro there was an option for hydraulic open/close trunk. Perhaps the L7 e38 has this option ?
    shogun what is this compartment showing in the video dirk linked ? Located in the middle of the 3rd row seat between the headrest, I’ve never seen that before.
    Jan 2005
    Japan
    Quote Originally Posted by e30luv318i View Post
    This video? https://www.youtube.com/watch?v=x82u6hXcXPg at which minute/seconds?
    warwick RI
    E30/E32/F25
    Yes above video At 6 min 30 sec shows read shade operations. Also shows the soft close door mechanism we just discussed! Very cool!
    Jan 2005
    Japan
    Just noticed that compartment between rear headrests now, never seen before.
    Jan 2005
    Japan
    The M70 engine explained in detail + assembling, about 25 minutes, BMW V12 Leichtmetall Motor M70 https://www.youtube.com/watch?v=aiEfxhB-_Dg&t=386s
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    New video!
    https://youtu.be/f1jf0Tee2jY
    Envoyé de mon SM-T700 en utilisant Tapatalk
    90,700 miles 1992 BMW 735iL Azure Blue Metallic with Silver Grey leather interior ‣My car ‣My YouTube channel
    Nov 2005
    Quebec Canada
    92 735iL (12/1991)
    Unsure if this is an old video, but it was new to me.
    "Entwicklung & Promotion BMW E32 730i - 750i - 1987"
  1. e32 On Board Diagnostics question
    By brokecolegelife in forum 1988 - 1994 (E32)
    Last Post: 03-01-2008, 05:51 PM
  2. BMW's latest technology- Auto-Park- (Video)
    By m3beemer16 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-17-2006, 03:14 AM
