Results 1 to 5 of 5
Thread: Can I reuse this clutch hardline (pic) or is it too far gone ?
    Oct 2008
    Belgium
    E32 M30 01-1987 Manual
    Hi,
    Very new to working on cars, so plz excuse the noobishness
    Recently inherited my grandpa's broken down E32... really always liked that car
    but the clutch master cilinder is toast
    After removing it, I found that the attached hardline had a slightly rusty screw on the
    end where it connects into the clutch master cilinder.. Can I reuse this or should I
    somehow replace it ?
    Or is it maybe a good idea to use a little teflon seal tape on the screw thread ?
    Or maybe that's a no no on brake lines ?
    If I have to replace it, is it possible to flare and bend new piece of hardline to the old OEM's spec using
    common flaring ( and bending ) tools ?
    And are the screws that go on each end of hard line standard stuff you can buy, or is it a
    special OEM BMW type of deal ?
    Or do I have to go about and hunt for a new piece of hardline from some E32 parts car ??
    Really hope no on that !
    Hope anyone can shed some light on this, as am very much clueless on this type of stuff !
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Post all E32 related questions in the E32 subforum, there are many experts for E32 and we have a detailed DIY. I will move it to there.
    Clean it with a small steel brush, the rush should go away and it will probably be re-usable. You can use Loctite 542 for hydraulic connections https://www.online-dichtungsshop.de/Loctite-542-10ml
    that is for hydraulic and pneumatic screw connections
    Here some links you need
    workshop manual https://www.bmwtechinfo.com/repair/main/
    wiring diagrams http://shark.armchair.mb.ca/~dave/BMW/e32/
    parts lists and diagrams https://www.realoem.com/bmw/select.do
    7.30i E32
    please add to your profile built year and month. 730i? straight 6 engine M30B30 engine or a 730 V8 with M60B30 engine? Better add details
    Oct 2008
    Belgium
    Thanks for the answer !
    Posted it in general because I thought it applied to pretty much all BMW's
    Gonna go for it and get some of that special lock tight, good tip
    Very handy links as well !!
    Jan 2017
    Carrboro, NC
    '91 525i (5sp)
    Mine looked a little bit worse when I replaced my master and slave, and it has held up perfectly fine for almost a year and a half (I have an E34, but same idea). If you want to be extra sure, you can coat the line itself with a rust-protective paint; not to sound like a commercial, but I'd use POR-15, if it's available there, that stuff is amazing!
    Feb 2008
    Nashville, Tennessee
    1978 635Csi, 1988 735iM
    I wouldnt put anything on the threads as thats not where that line seals. You just need to clean the threads with a soft bristle wire brush (like brass). and maybe wd40 where the line goes through the nut so itll spin freely.
  1. Replies: 47
    Last Post: 09-06-2007, 05:33 PM
  2. Clutch Stop [PIC]
    By mattd860 in forum 1983 - 1991 (E30)
    Last Post: 08-13-2006, 01:56 AM
  3. What part am I missing? Clutch related - Pics Inside...
    By Pink Floyd in forum 1992 - 1999 M3 (E36)
    Last Post: 08-23-2005, 02:54 AM
  4. Trashed Clutch Disk (Pic inside)
    By sandsrfr in forum 1991 - 1999 (E36)
    Last Post: 09-09-2004, 03:09 AM
