Results 1 to 6 of 6
Thread: exhaust question
    Apr 2018
    pa
    2010 bmw 535I XDRIVE
    exhaust question
    2010 535I X drive with stock exhaust has 2 exit tips on the left side. the left tip has pressure coming out and appears to be the muffler. The right tip looks like it is hooked to a square I assume muffler but has no pressure coming out. Whats going on?
    Dec 2016
    Orlando
    '08 E60 528i
    the 535i has a valve on the exhaust to reduce sound until the engine is at higher rpms, then the other tip can breathe and makes the exhaust a little louder
    Apr 2018
    pa
    Thanks. I was just wondering. I Am still chasing the limp mode problem,still checking all hoses and crossover pipe for cracks and turbo diverter valves.
    Just wondering if it will still pass inspection since it does not come on unless you get on it.
    Oct 2003
    Seattle
    99 M3
    The ECM needs to have “ready” code(s) in place to pass OBDII interrogation.…and those may not be in place IF you can ‘throw’ a CE light and initiate “limp mode” on demand.
    Mar 2011
    OK
    e30, e61
    Have you checked the codes that are causing the limp mode?
    Apr 2018
    pa
    I have not gotten a specific bmw code reader yet. My OBD2 code reader will pull any up.
  1. exhaust question
    By arrogantBMWdriver in forum 1999 - 2006 (E46)
    Last Post: 01-30-2009, 05:19 PM
  2. AA E46 exhaust question
    By e46driver in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-23-2001, 05:16 PM
  3. 328i exhaust question
    By djbeemer in forum 1991 - 1999 (E36)
    Last Post: 06-20-2001, 04:20 AM
  4. Exhaust question for 318...
    By Austin in forum 1991 - 1999 (E36)
    Last Post: 04-09-2001, 04:49 PM
  5. Quick exhaust question for alla yall
    By Anfanger in forum 1991 - 1999 (E36)
    Last Post: 04-04-2001, 09:25 AM
