Page 8 of 12 FirstFirst 123456789101112 LastLast
Results 176 to 200 of 282
Thread: Turbo M60 e34 Big-Power Content Inside
  1. #176
    Dec 2005
    Melbourne, Australia
    M3evo-Twin Screw/M635csi
    Nice to see it finally make nice power. Sometimes projects take much more time than first estimated
    BMWs
    74 2002 2.3ltr
    84 E24 M635csi
    94 E34 540i/6 SC 16psi E85
    97 E36 M3 euro SC still u/c
    OTHERS
    11 Audi S5 APR
  2. #177
    DeWitt, Michigan
    '97 540i/6, '97 328i
    I finally got back to my computer today so I could take a close look at the graphs. And wow, for 91 octane, those numbers are excellent!! I would really love to see what you could get out of it on E85, because now that E85 is a thing, boosted life on 91 octane is bad. Lol.. Did you say why you didn't set it up on E85? If so I missed it.
    And other than that, all I can say is that if the boost actually comes in before 5k as projected on the street, it's going to be a fantastic thing that this is an M60 based build, with it's larger diameter clutch surface (than what is possible on the M62). That torque is going to be brutal on the clutch! Love it.
  3. #178
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by tptrsn View Post
    Agreed, we are really happy with how it turned out.
    We originally talked about e85 being a possibility for high boost, but after we got more involved with the car and a deeper understanding of Jims goals we really couldnt justify pushing it any harder.
    As of now its making huge power on pump gas, its exceeds the build expectation, its simple and its reliable. Plus it gets back in Jims hands sooner.
    1989 535i - sold
    1999 Tiag/Dove M3 - sold
    1998 Turbo Arctic/black - current
    2004 TiAg/Black - Current
    PTE6870 | 1.15 ar | Hp Cover, Custom Divided T4 bottom-mount, 3.5" SS exhaust, Dual Turbosmart Compgates, Turbosmart Raceport BOV, 3.5" Treadstone Intercooler, 3.5" Vibrant resonator and muffler, Arp 2k Headstuds | Arp 2k Main studs | 87mm Je pistons | Eagle rods | 9.2:1 static compression, Ces 87mm cutring, Custom solid rear subframe bushings, Akg 85d diff bushings, 4 clutch 3.15 diff, , Poly engine mounts, UUC trans mounts W/ enforcers, 22RPD OBD2 Stock ECU id1700 E85 tune, 22RPD Big power Transmission swap w/ GS6-53
  4. #179
    DeWitt, Michigan
    We do get a little spoiled in this part of the country, where it makes zero sense to run a turbo build on anything but E85. But when I drove out west, I started understanding how difficult it can be to even find gas as "good" as 91, so I do get it. Especially when you can make the kind of power you got out of 91. Having the tune only require 91 octane would be a fairly huge convenience factor out there.
  5. #180
    Bellingham, WA
    e30
    Unfortunately E85 isnt as common on the West Coast like you said. Too bad it never seemed to pop up out here.
    91 is about all you can reliably get so its a great choice to tune to!
  6. #181
    DeWitt, Michigan
    Yeah, without getting into any of the other aspects of E85 (political or economic stuff), it is one of the biggest boons for the performance car industry since the turbocharger. Such an impressive safety net for a forced induction engine, and yes, big shame it isn't everywhere for those of us who love to play with cars.
    With that said, I'll reiterate how impressed I am with this level of power on a 91 tune, especially with the A2W intercooler not cooled by an ice bath. I'm sure the non-factory cams help out a lot, but still, very impressed.
  7. #182
    Dec 2014
    Marin,Ca.
    4.9L 540i/Porsche 997
    Clutch is a Cluthmaster 850, good for high hp/trq.
    22RPD Tuning '95 540i/6 custom turbo mit Borg Warner S400sxe/Rebello Racing 4.9L M62/JE pistons/Arrow rods/custom cams/S62 crankshaft/Darton sleeved/Focal custom stereo
    Porsche 996 Turbo Evosport GT 700-[700hp]-my daily
  8. #183
    DeWitt, Michigan
    Yeah, hopefully it will be, and I would expect it will be good. If it was made for the smaller diameter of the M62 clutch friction surface though.... Then not so much confidence! M60 platform holds many advantages for bewsties.
  9. #184
    Dec 2014
    Marin,Ca.
    If anybody hs any recommendations on a reliable, honest (as much as possible ) reasonably priced auto carrier from Washington to 94949, please let me know asap. Thanks!
    Has a JB Racing LWFW.
    ***** I found a open carrier shipper for $600 form WA to CA. Does this sound reasonable?*****
  10. #185
    Mar 2012
    Renton, Wa
    98 m3
    Jim, Thats about average for a running car for that distance. Maybe 10% high.
    So guys I took the car for about a 30 minute trip today. Fine tuning some drivability, hot start and idle. I got the closed Loop idle dialed in and its rock solid.. that always a good feeling.
    I had the car down at spring pressure (7psi) and were seeing full boost by about 4000 just looking at the fuel trim logs.
    7 psi is enough to blow the tires off... which is scary as heck with the suspension package thats on it.
    Theres a throttle position where the turbo overcomes the blow off valve and you can keep the wooosh open as long as you want.. which is hilarious.
    On the way back to the shop a valvecover bolt/seal worked loose and oil dripped onto the exhaust scaring the heck out of me
    Really a fun car. Id love to put about 300 miles on it and make sure there are no more surprises like the bolt above. I dont think many will realize how custom this car is.. very few parts are factory..
    1989 535i - sold
  11. #186
    Dec 2014
    Marin,Ca.
    Zack, if you can before you schedule pick-up, please go ahead and put some miles on "Thor" .
  12. #187
    Dec 2005
    Great that it’s coming together. Excellent that the m60/2 platform gets the loving it deserves. Projects like this never seem to end. Chassis is always something that needs to be considered with power like 700rwhp+. My e34 is approaching 500rwhp and it’s pretty drivable with a tight lsd, upgraded bushes and some pretty sticky Yokohama AD08R tyres. On the worn pilot supersports it was a handful especially trying to manage acceleration under corner exists. I see u run 7psi spring on the wastegate. That’s about what I run in mine with a 3 port solenoid for an in cabin 7psi/16psi switch.
    BMWs
    74 2002 2.3ltr
    84 E24 M635csi
    OTHERS
    11 Audi S5 APR
  13. #188
    Dec 2012
    LA
    1999 BMW M3 Coupe
    Congrats to jimmyz66 on this one of the greatest e34 build.
    I remember 4 or 5 years ago I saw his supercharged e34 pictures and I was setting it as a goal to reach. I only had 530i becoming 540 back than. now thanks to jimmy and 22rpd even crazier stuff is available.
    Great work guys!
  14. #189
    Jul 2018
    San Francisco
    E92 335i, Z3 Roadster
    Quote Originally Posted by jimmyz66 View Post
    Hey Jimmy, I live just south of you in Lafayette and have been toying with the idea of boosting my 530it. I'd love to check out your build if you are open to it. Do you plan on heading to Sonoma one of these wednesday nights before the season ends?
  15. #190
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Good job Gents. I thought you never finalize it. Thanks God i was wrong. I have m62 oem exhaust and modified it for turbo. After 7psi have no gain in power up to 13psi. What should be minimum exhaust manifolds diameter for m62 turbo for 15psi? Turbo is hx40, injectors 630cc. Thanks in advance.
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc
  16. #191
    Dec 2014
    Marin,Ca.
    bmwgruzin, thanks, much appreciated.
    Czechmate, you are more than welcome to come over to Marin. I am not into 1/4 mile from dead stop. More into 1/2 mile runs from a 30 mph roll or so. Easier on my trans.
    doviet, I would call Zack at 22RPD.
    Well hopefully tomorrow I will finally get to test the big boy out. I had a problem with low voltage to the engine due to my new new Hi Tech stereo install. Realced the battery terminals and wiring ( the low voltage was fouling up my plugs within seconds).Got that fixed and ordered new NGK Race plugs. I will then take my 540i/6 to Sonoma Raceway to have Tim Barber install a new suspension set-up to kill the mean rear squat I get now with my old Dinan set-up. In the mean time I am having fun with my Porsche 996TT Evomotorports GT700-soon to be 800 hp. It literally takes seconds to get to 150 mph (in Mexico of course ) But, I just love the "psssst" sound off boost of the turbo in my 540i/6. Awesome!
  17. #192
    DeWitt, Michigan
    Just an FYI, this is not necessarily true at all. You can drive off the line like you would from a stop light, and get a solid quarter mile TRAP SPEED for your car. Trap speed is really the measure of how fast the car accelerates.
    Elapsed time is what depends on launching like a drag car, since it is highly dependent on what happens in the first 60ft. So for cars like ours, there is no reason to bother with it. Just come off the line like you would in an enthusiastic start on the street, and then let 'er rip. MUCH fun to be had that way, without putting undue stress on the driveline.
  18. #193
    Dec 2014
    Marin,Ca.
    tptrn- thanks for your reply, but I respectfully disagree. Continuous hard launches in 1st gear over time will indeed but undue stress and wear on clutch and trans. If PDK with launch control, ok fine.
  19. #194
    DeWitt, Michigan
    There really doesn't have to be any extra wear on the clutch at all, but suit yourself.
  20. #195
    Apr 2006
    Minnesota eh?
    86 325es
    What he is saying is just do a no power leave and roll into it half way through 1st gear. Ignore the time on the slip and just race for trap speed.
  21. #196
    DeWitt, Michigan
  22. #197
    Jul 2018
    San Francisco
    [QUOTE=jimmyz66;30358424]bmwgruzin, thanks, much appreciated.
    /QUOTE]
    What's the best contact to reach you at? I dont have the option to send private messages on the forum.
  23. #198
    Jul 2011
    Bay Area, California
    M3 w/Gt35r
    Yea! Lets get the Bay Area BMW turbo gang together!
  24. #199
    Dec 2014
    Marin,Ca.
    Zack please call me asap. Once again Zack, PLEASE call me, and check pm. This is getting tiresome.
  25. #200
    Dec 2014
    Marin,Ca.
    Hi, if anyone kws how to get a hold of Zack, please have him call me. I do not, I repeat, do not like to come on here like this. I am just trying to get a hold of Zack, and cannot. Yes, tried calling and using pm.
  1. New HI member. (E34 540it 6spd) content inside.
    By daleyswanson in forum Hawaii & Other Islands
    Last Post: 04-09-2014, 02:11 AM
  2. Another chip thread.. M60 content inside
    By Lord DRIFT in forum 1988 - 1996 (E34)
    Last Post: 12-25-2008, 10:15 PM
  3. EUROPROJEKTZ- Turbo e36 M3 video content inside
    By M3Style95 in forum BMW Rides & Events
    Last Post: 01-25-2008, 02:59 PM
  4. GT42R Turbo, looking for big power?
    By JBgotM in forum Race Cars & Track Parts
    Last Post: 12-05-2007, 10:52 AM
  5. 8 sec 1/4 Turbo Power Vid inside!!!!
    By rundatrack in forum Forced Induction
    Last Post: 10-01-2007, 11:08 AM
