Page 7 of 12 FirstFirst 123456789101112 LastLast
Results 151 to 175 of 282
Thread: Turbo M60 e34 Big-Power Content Inside
  1. #151
    Jul 2011
    Bay Area, California
    M3 w/Gt35r
    Any interest in going to the Wednesday night drags at Sonoma once it’s done?
    I definitely want to get my car up there to have some fun...
  2. #152
    Mar 2015
    Vancouver, BC, Canada
    2014 Alpina B7
    Definitely need plenty of videos!!
  3. #153
    Dec 2014
    Marin,Ca.
    4.9L 540i/Porsche 997
    Quote Originally Posted by IR M5 View Post
    I would differently be all over the Sonoma races as I live 15 minutes from there in Novato. However, I will only do dog races from a 30 mph start. BMW's, unless built for standing still races, are not usually made for this type of drag races. But, who know, I will have to make some tough decisions. Hope to see a fellow BFC member there.
    22RPD Tuning '95 540i/6 custom turbo mit Borg Warner S400sxe/Rebello Racing 4.9L M62/JE pistons/Arrow rods/custom cams/S62 crankshaft/Darton sleeved/Focal custom stereo
    Porsche 996 Turbo Evosport GT 700-[700hp]-my daily
  4. #154
    Jun 2013
    Southern California
    1995 540/6 Calypsorot
    What happened with this build?
    Jason Grace
  5. #155
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by UnrulyGrace View Post
    The turbo build is long finished.
    Currently the suspension is off and going through an overhaul.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  6. #156
    DeWitt, Michigan
    '97 540i/6, '97 328i
  7. #157
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by tptrsn View Post
    So what was the power outcome?
    The time between fixing the issues we had on the first dyno day, and pulling the car apart for suspension coincided with our new dyno install so no final figures until we get it back together.
    1989 535i - sold
  8. #158
    DeWitt, Michigan
    Thanks!
  9. #159
    Dec 2005
    Melbourne, Australia
    E24, E34 x2, E36
    It would be nice to see how it ended up
    BMW’s
    90 E34 M5
    84 E24 M635csi standalone ecu with coil on plug
    94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
    97 Z3 2.8
    97 E36 M3 euro SC still u/c
    OTHERS
    11 Audi S5 APR stg2
    19 Volkswagen Amarok V6
  10. #160
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    For me looks like never end. Hope this time there will be no any surprises and all of us will see happy end....
    Owner of current project is real man that he still write here politely and keep column..... Good luck.
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
  11. #161
    Dec 2014
    Marin,Ca.
    Quote Originally Posted by dovlet View Post
    Thanks, I went with Ground Control, and it looks like about 2 weeks I will be picking her up. Also have been putting in a lot of time on my new (used) 700 hp Porsche 996 TT Evosport GT700. Now doing a full custom JL Audio stereo with 13" shallow sub. Bose sucks big time
  12. #162
    Sep 2002
    USA
    BMWs
    Were you able to get this thing tuned and making power?
  13. #163
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by 5mall5nail5 View Post
    We partially tuned it last year before we had the issues with the motor.
    We just put it back on it’s own suspension today, and on the dyno.
    Went through a set of plugs and the usual troubleshooting until we got it running nice again. Needed a bunch of retuning. We also previously cleaned up the harness and some wires didn’t get reconnected which caused a fuss today.
    We got all the part throttle dialed back in up-to 100kpa and started into boost. Coolant line from the previous builder started to leak and so we got to do a coolant flush on the dyno.
    Then it wasn’t making really any boost until redline, so we pressure tested It.. leaks all over. pulled the charge-pipes and throttle off.. resealed the tb to (the not so flat) inlet flange. Fixed everything up and Left it all to dry. Probably another set of steadystate to make up for the leaks..
    Steady state upto 100kpa was showing like 275whp, and with a just a little boost we’re like double that, timing peak around 15* in boost, lots on the table. We didn’t really run it above 6000 either.
    Hoping to wrap it up tomorrow, but you know how that goes.
    1989 535i - sold
  14. #164
    Dec 2014
    Marin,Ca.
    Quote Originally Posted by jimmyz66 View Post
    Edit and change: I changed my mind and will have shipped back to me w/o Ground Control suspension. Also looking at KW Variant 2's. Thoughts? Thanks. Zack- LOL, I am ready to throw in the towel, but it won't leave my hand. It is stuck to it!
  15. #165
    May 2003
    Tampa, FL
    E92 M3, 970TT
    You'll be buried in this car Jimmy! Call Wyatt with MCS and see if he'll put together a setup for you.
    991 | 964 | G55 | D90 | LX570 |
    Past: SC'd e34 540/6, CSL'd E46 M3, E36 M3/4/5, E36 M3 turbo, E36 M3, 335D, Porsche 951, 80 Series LC, Kleeman E55 Wagon, LX470, 970 Panamera TT, E92 M3
  16. #166
    Dec 2014
    Marin,Ca.
    Quote Originally Posted by E34nication View Post
    Thanks, much appreciated, but I will try the KW Variant 2's and have a local tech install and dial in the suspension. This way I can easily change things if needed. And, I can sell my Dinan/Koni set-up. This, my new to me 996 TT, and selling my house to move to Bend, OR. or Baja. I have a fun, full plate for sure.
  17. #167
    Mar 2012
    Renton, Wa
    98 m3
    Got the car dialed in yesterday under boost, 7 / 10 / 14 /18 psi settings.
    We're working with low octane ratings here, and since the engine builder is unable to provide the specifications on the pistons we are a bit hesitant to go above 18psi.
    We did a compression test the other day, and compression figures were very high. Close to what we see out of a healthy s52 at this altitude. So while we trust the motor was built for boost, we are hesitant to push too hard.
    Additionally, the alternator runs 19V above 3000rpm.
    ill post graphs later!
    1989 535i - sold
  18. #168
    Missouri
    '02 540i/6
    Quote Originally Posted by vollosso View Post
    We're eager to finally see some numbers!
    2002 BMW Titanium Silver 540i/6-speed Sport - ZHP Shift Knob - M5 Clutch/TTV Racing 15.6lb Flywheel - M60 Intake Manifold - N62 84mm TB - Dinan Intake Tube - 4" MAF Tube - DUDMD Tune - Magnaflow Resonator - Eibach 18mm Rear Sway Bar - Powerflex Front Sway Bar Bushings - CDV Delete - UUC SS Brake Lines - Koni Yellow Shocks/Struts - Eibach Springs - Zionsville Radiator & FDM
  19. #169
    Mar 2012
    Baltimore, Maryland
    2016 640i, 1990 535iM
    ^ agreed
    2016 640i Coupe'
    1990 Bmw 535i Turbo 600whp
    1999 740iL: Sold
    1997 740i: Crashed and Parted
    1988 535i: Crashed and Parted
    1988 528e: Crashed and parted
    IG- @Rogetta_Stone
  20. #170
    Mar 2012
    Renton, Wa
    98 m3
    Just wrapped it up.
    Dyno sheets from yesterday showing multiple boost levels:
    Dyno sheets from today, fine tuning high boost:
    SAE CORRECTED
    Uncorrected figures
    Final Figures from yesterday versus today, 1-1.5 psi less boost today with fuel and timing fine tuning:
    After talking with the engine builders today for quite some time. We settled on a final boost figure of 17psi (215kpa target) for 91 octane fuel.
    Jim came to us asking for genuine 600whp car, we were shooting for 700whp on pump. We are all really happy the car is sorted, making good power (Even if it is 4% less than we were hoping for).
    Dyno videos to follow.
    A FINAL NOTE! For final power figures we run inertia tests, and this is a low inertia dyno. These dyno pulls are only 3 seconds long, the spool looks slow on these pulls but during loaded tuning/testing we are seeing full boost down by 4500. We expect full boost on the street to be around 4250. Redline of 7200.
    Thanks for reading!
    -Zack
    1989 535i - sold
  21. #171
    Mar 2015
    2014 Alpina B7
    Wow those curves are so nice
  22. #172
    Dec 2014
    Marin,Ca.
    Thank Zack! And for all your hard work and excellent customer service. I am very lucky to have met you here on BFC. And also a big thanks to BFC for the members help and advice, other wise (LOL-also crying at the same time) I would be stuck with Osh/RMS.
    ***** Any suggestions on shipping outfits to get my car back down to 94949 would be greatly appreciated!*****
  23. #173
    Bellingham, WA
    e30
    Awesome results! Finally this car is working properly!!
  24. #174
    Missouri
    '02 540i/6
    Take a vacation, fly up, drive it back down.
  25. #175
    Dec 2014
    Marin,Ca.
    Quote Originally Posted by Iamthebull View Post
    Would love to but not possible.
  1. New HI member. (E34 540it 6spd) content inside.
    By daleyswanson in forum Hawaii & Other Islands
    Last Post: 04-09-2014, 02:11 AM
  2. Another chip thread.. M60 content inside
    By Lord DRIFT in forum 1988 - 1996 (E34)
    Last Post: 12-25-2008, 10:15 PM
  3. EUROPROJEKTZ- Turbo e36 M3 video content inside
    By M3Style95 in forum BMW Rides & Events
    Last Post: 01-25-2008, 02:59 PM
  4. GT42R Turbo, looking for big power?
    By JBgotM in forum Race Cars & Track Parts
    Last Post: 12-05-2007, 10:52 AM
  5. 8 sec 1/4 Turbo Power Vid inside!!!!
    By rundatrack in forum Forced Induction
    Last Post: 10-01-2007, 11:08 AM
