Results 1 to 7 of 7
Thread: M50 manifold swap with oil catch can
    Mar 2014
    Spokane valley, wa
    97 m3 sedan second one
    My question is when doing a m50 manifold swap would I still need to buy the kit or would I just plug the hole like in my s52 manifold? I already did a ccv delete and installed a catch can. I can't find much info on people running catch cans on e36s.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Turbo guys run catch cans and most have M50 manifolds.
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    I just run a large rubber line from my valve cover to under the car to the ground...no catch can. I see a drop of oil maybe once a year, after the car has been sitting for months
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    Open air CCV just plain stinks. Personally I would retain an OEM style closed system. S62 oil separator or the custom style supercharger “catch can” I build are easy to integrate. I know you’re not boosted, but it all works the same.
    Pull vacuum post MAF (metered side) and drain back to the oil pan.
    Mar 2014
    Spokane valley, wa
    Quote Originally Posted by Braymond141 View Post
    I have the catch can already set up like you said with it pulling the vacuum and draining back. I just needed to know if with a m50 manifold would I just plug the hole like I did on the s52 manifold or do I have to buy the m50 swap kit?
    Jan 2006
    Oakhurst, CA
    Quote Originally Posted by fuginusername View Post
    What hole in the M50?
    The swap kit adds the hole back. The M50 has no CCV port, the hole is for the ICV.
    Mar 2014
    Spokane valley, wa
    Thank you. I always assumed that the m50 manifold had that same hole in it just from the way the kits looked. That's what I get for assuming something.
  1. m50 manifold swap. What options for oil dip-stick tube?
    By Jean-Claude in forum 1992 - 1999 M3 (E36)
    Last Post: 05-25-2006, 09:29 AM
  2. M50 manifold swap question
    By 96technoM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-23-2004, 01:48 PM
  3. Dyno results after M50 manifold swap and UUC pulleys
    By BGM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-17-2003, 11:28 AM
  4. M50 manifold swap on OBDII car
    Last Post: 11-19-2003, 11:55 PM
  5. Review/impression of M50 manifold swap.
    By ARCpolo in forum 1992 - 1999 M3 (E36)
    Last Post: 09-02-2003, 09:53 PM
