Results 1 to 3 of 3
    Northwest Ohio
    2001 750iL
    E70 3.0 Buying Tips
    Going to look at adding a 2009 E70 3.0 to the fleet tomorrow. From what I can see the N52B30 looks to be a reliable engine with the exception of vanos solenoid and hydraulic lifter issues. And I've found this mentions a few things to look for. We've got a few E53s already. So other than the normal suspension and cooling system issues are there any other things I need to look for?
    2005 X5 4.8is (DD winter) * 2001 750iL (DD summer) * 2001 Ford Excursion 7.3 L <> 2005 X5 3.0 * 2003 X5 4.4i * 2009 X3 3.0 * 2009 X5 3.0 * 2007 Toyota Avalon Limited
    Halifax, Nova Scotia
    2001 530i, 2007 X5 3.0si
    I was in the same boat as you a while ago when looking at e70's. I couldn't really find a comprehensive "things that go wrong list" that I easily found when shopping for my e39.
    Anyway, don't consider what I say to be all encompassing, but just things to look out for/keep in mind:
    -The water pump (only one) is electric and is known to fail (you can read the water pump error messages on INPA - if you start getting them, you should replace)
    I replaced mine last year.
    -The idler pulleys/tensioners can become weak and misaligned. This just seems to be an issue with the N52. If the misalignment is bad, the belt can slip off apparently.
    I replaced all pullys/tensioners and belts last year.
    -Just like most other BMW's, the cooling system should be watched and preventatively replaced. The previous owner of mine replaced most of the hoses and I replaced the expansion tank.
    -Valve cover gasket/ oil cooler leaks like on most other BMW's
    That's all I can think of for now. It may sound like a lot of issues, but a lot less things seem to go wrong on the X5 compared to my e39 530i, and I am still very happy to have bought the X5.
    Note: I just noticed that your post is dated 3 days ago, and you say that you may pick up the X5 the day after your post - so this info is probably useless, but I'll post anyway if it helps someone else out.
    Northwest Ohio
    2001 750iL
    Thanks for sharing Chris. Yes. We did end up getting it. But not for a few days after my post, after coming to a deal. They had already replaced the water pump so I can check that off the list. Needs a wheel bearing and hub in the front, brakes and tires after 68K miles. Not too bad I would say.
  1. e39 540i buying tips?
    By potpie in forum 1996 - 2003 (E39)
    Last Post: 05-18-2003, 07:49 PM
  2. 5-Series Overview, buying tips
    By TalShiar in forum 1988 - 1996 (E34)
    Last Post: 02-04-2003, 04:10 PM
  3. Car Buying Tips
    By dbarberic in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-20-2002, 08:41 PM
  4. M3 Buying Tips?
    By Mako in forum 2001 - 2006 M3 (E46)
    Last Post: 10-03-2002, 02:16 PM
  5. buying tips on an E36
    By justinosman in forum 1992 - 1999 M3 (E36)
    Last Post: 02-01-2002, 12:54 AM
