Bavarian Soundwerks
Results 1 to 3 of 3
Thread: can i use a nav head with a non nav dsp amp
    Sep 2018
    brookings sd
    2000 bmw x5, 1987 535is
    I have not found an answer to my question so far forgive me if i missed it in my searching
    I have a 2000 BMW x5 with the non navigation dsp radio and buisness cd player. in the back there are extra plugs on the harnesses buy the amp. can i run a nav head unit without needing all the nav parts? just want to use it for the radio as min is pixelated and the repair went bad. i dont need navigation just like the look of the nav unit in the dash.
    Sodakjones
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I think the head unit in BMWs with nav in that era are merely man-machine interfaces. That is, as your X5 does not have nav, the head unit contains a lot of the electronix such as the radio. Swapping in a nav head unit will require the installation of the electronix in the “trunk.” Also, it’ll require a wiring harness swap.
    Sep 2008
    West London/Heathrow - UK
    03 530dT - Ex Police Car
    Hi,
    No. You can't use the OEM monitor with the setup you have already. You'll need to change the loom in order to be able to fit the BM53 amplifier module, a video module. The CD changer is optional and if you chose to add the Mk4 DVD based navigation module, you'd not need the aforementioned video module as it's capable of driving the monitor directly.
    It's been asked many times over all the BMW forums.
    Cheers, Dennis!
  1. Anybody here have a 2.7 stroker using the 323i head
    By BIMMERBOYZ in forum 1975 - 1983 (E21)
    Last Post: 11-30-2007, 12:07 AM
  2. Anyone use these ebay head bolts?
    By Eric1H in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-21-2006, 11:04 AM
  3. What sealant to use for cylinder head gaskets?
    By olsen185 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-24-2005, 07:16 PM
  4. can I put subs in my 528i, if I'm using the stock head unit?
    By toofast4U in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-27-2003, 12:54 AM
  5. Does using a new head unit make sound better?
    By M3D in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-28-2001, 05:49 PM
