Results 1 to 9 of 9
Thread: Rough idle
    Sep 2018
    pacoima,ca,usa
    2002 bmw 325i
    Rough idle
    Ok so I cleaned the intake replaced my intake boot and checked my hoses, and it still has a bank 1 bank 2 too lean code. I have switched the MAF sensor with 2 different ones and it idles worse. I really don't think it could be my MAF sensor, or could it??
    Sent from my SM-G950U1 using Tapatalk
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The first step in diagnosing a problem is to scan the engine computer (DME) for codes. I bet you’ll end up with codes P0171 and P0174. They are classic indicators of vacuum leaks. The only way to find all of the leaks is to have the intake manifold smoke tested.
    Please stop throwing parts at the problem. That wastes money, doesn’t fix the problem and it angers the BMW goddesses.
    Sep 2018
    pacoima,ca,usa
    2002 bmw 325i
    Sorry I didn't mention that my intake boot was ripped
    Dec 2013
    Chicagoland area
    EXOTICS
    Test the fuel pressure at the fuel rail Schrader valve.
    Test at idle-2000rpm-3000rpm.
    report back with psi readings.
    Sep 2018
    pacoima,ca,usa
    2002 bmw 325i
    Ok so I noticed that when I take off the oil cap the engine starts to shake alot, like it wants to turn off.. the oil cap has alittle vacuum when I take it off. And when I put my hand over it. Could it be my cvc? Those are pictures of it from the bottom. Is that with in the normal range??
    Dec 2013
    Chicagoland area
    EXOTICS
    From the looks of it, your CCV Valve seems to be leaking oil,
    Replace the CCV System:https://www.fcpeuro.com/BMW-parts/32...002&m=20&e=177
    Sep 2018
    pacoima,ca,usa
    2002 bmw 325i
    Ok so I got the ccv replaced got the cranck case sensor replaced and the fuel pressure regulator with fuel filter replaced and I still have lean codes...wtf???
    Jan 2017
    USA
    E21, E46
    Rough idle
    Use a smoke machine to find the source.
    You more than likely have multiple leaks.
    Dec 2013
    Chicagoland area
    EXOTICS
    Quote Originally Posted by MIKYZZ4 View Post
    Quote Originally Posted by RobertDenali View Post
    You seem to have only partially performed the recommended suggestions,
    and replaced other parts that were never mentioned.
  1. Rough Idle Q's, and SF Stealers
    By C.Yang in forum 1992 - 1999 M3 (E36)
    Last Post: 08-14-2001, 03:26 AM
  2. Rough Idle
    By daytonflyer53 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-05-2001, 09:42 PM
  3. Help! Rough Idle
    By dakowals in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-04-2001, 11:35 PM
  4. Rough idle issue
    By jayhudson in forum 1992 - 1999 M3 (E36)
    Last Post: 05-15-2001, 11:04 PM
  5. Rough Idling
    By jaramill in forum 1992 - 1999 M3 (E36)
    Last Post: 04-13-2001, 10:10 AM
