I have an 98 vert with manual seats. I must have a piece of gravel or a coin in the track under my driver’s side seat because every couple days it screeches when I slide it forward and sometimes won’t go all the way forward. This’ll last a couple trips, then fix itself for a while. I can’t see much of the track because of all the trim along the bottom of the seat, so I’m thinking I’ll have to pull the seat. How much of a hassle am I in for if I can’t just shake watever it is out and have to take the track apart?
You should take the seat out while it's still able to move. It's an easy process. slide it all the way back and remove the front fasteners then slide it forward and remove the back two. Unplug any wiring under the seat and take it out for access to the tracks. If you look under the seat with a flashlight you may see the problem and be able to pick it out with a tool without removal. Slide it to both limits when looking underneath.
Update: the weekend schedule & weather finally aligned and I yanked the seat yesterday. The rail started sliding smoothly as soon as I had the seat turned sideways. I hit both rails with some canned air followed by the shop vac, anyway, and got the carpet pretty well while I had access. What's the recommended lubricant for those- would silicone spray work now that I have the seat reinstalled?
Thanks for the advice above!
