Results 1 to 9 of 9
Thread: Keep It Simple Stupid; an e23 Build Thread
    Jul 2018
    Gilbert, AZ
    1987 BMW 735i
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    What is the plan?
    Also, nice broom handle holding the hood open.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Jul 2018
    Gilbert, AZ
    1987 BMW 735i
    Quote Originally Posted by Hit Man X View Post
    What is the plan?
    Ha! I will be adding some background and more photos soon! I was just in a hurry and wanted to get a few of the first photos up!
    PVC pipe comes in handy! Somewhere way down on the list of things to fix are the hood struts.
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Hahaha, just jabbin' ya. I have done that before too.
    Looks like you have a trans fault lamp illuminated...car only have third and reverse?
    Late 85 to early 86 car I assume? You have all the updated HVAC stuff, good base.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    Jul 2018
    Gilbert, AZ
    1987 BMW 735i
    Correct, it’s currently in limp mode and I have not gone through the processes of elimination to determine what is causing it.
    It currently will not start (starter is to blame based on not able to jump via pin 11 and 14). Getting ready to pull the starter out and bench test it before ordering a Bosch replacement.
    Once that is rolling I’m eager to take it to emissions testing and get it to pass. Purchased with rearward muffler in trunk and the forward muffler dangling by the rubber hangars a couple days later. Passed everything except NOx levels by .02 grams/mile with a cat back straight pipe. Assuming I can go earlier in the day with fresh oil and get it to pass that state req.
    It is a 5/86 stamped car.
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Do the B35 starter and install block studs while in there. I have a write up floating around on here somewhere. SR441X I think is the part number.
    Check the relay in the passenger kickpanel, well it should be there for the trans. There is also a large connector in there with 10-12 pins that piggybacks the ECU harness, verify plugged in. And of course the case connector itself. I would remove and douche with Deoxit, both male and female sides.
    Wow, 05/86 is basically end of the line. Neat!
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    Jun 2015
    Los Angeles
    1981 Euro 732i
    Clean looking ride.
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    Kris Burrito is in Mesa, he is down the street from ya... and has my old 11/84 745i in Cosmos. You should harass him to plop the M102 into it I gave him...car has BBSs, Bil HDs all around, LSD, rear power seats, no factory rear speakers!
    BTW, those 15" wheels on the '86 make ideal spare tires. The E38 'style 5' do not fit in the hole with a 225/50R16.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    Jul 2018
    Gilbert, AZ
    1987 BMW 735i
    Quote Originally Posted by 7THRTY2 View Post
    Clean looking ride.
    Thank you sir! I have some plans for it that may invite the purists to come out and play..... but I won’t release too many details yet!
    I’ll have to hunt him down! I’m lucky enough to have an LSD from the factory and the rear privacy screen, a neat feature that’ll go well with some of the “executive” plans I have.
    I promise the details are still coming. I’m in the middle of a move and for some reason the girlfriend deemed unpacking and furniture rearranging a priority.
    I I have a write up from mye28 that seemed really laid out and relateable with the shared m30. And correct on that starter number! I will hunt your walk through down as well as additional info.
  1. Addam's 1979 E23 Manual 733i Build Thread
    By ozibimmer in forum 1978 - 1987 (E23)
    Last Post: 06-05-2014, 05:51 AM
  2. The Official Engine Building Thread
    By iamane30m20nut in forum 1983 - 1991 (E30)
    Last Post: 01-03-2006, 01:43 PM
  3. MY Cage Build Thread :) (56k beware)
    By magnetic1 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 08-22-2005, 02:04 AM
  4. New Cage Build Thread (56K beware)
    By B.Watts in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-23-2005, 10:59 AM
  5. OK guys...just to keep it simple...
    By AvusBluR in forum Off-Topic
    Last Post: 09-13-2002, 08:51 AM
