What is the plan?
Also, nice broom handle holding the hood open.
I make E23 parts.
10/1984 745i
11/1984 745i
11/1984 735i (10:1-265/6)
Hahaha, just jabbin' ya. I have done that before too.
Looks like you have a trans fault lamp illuminated...car only have third and reverse?
Late 85 to early 86 car I assume? You have all the updated HVAC stuff, good base.
I make E23 parts.
10/1984 745i
11/1984 745i
Correct, it’s currently in limp mode and I have not gone through the processes of elimination to determine what is causing it.
It currently will not start (starter is to blame based on not able to jump via pin 11 and 14). Getting ready to pull the starter out and bench test it before ordering a Bosch replacement.
Once that is rolling I’m eager to take it to emissions testing and get it to pass. Purchased with rearward muffler in trunk and the forward muffler dangling by the rubber hangars a couple days later. Passed everything except NOx levels by .02 grams/mile with a cat back straight pipe. Assuming I can go earlier in the day with fresh oil and get it to pass that state req.
It is a 5/86 stamped car.
Do the B35 starter and install block studs while in there. I have a write up floating around on here somewhere. SR441X I think is the part number.
Check the relay in the passenger kickpanel, well it should be there for the trans. There is also a large connector in there with 10-12 pins that piggybacks the ECU harness, verify plugged in. And of course the case connector itself. I would remove and douche with Deoxit, both male and female sides.
Wow, 05/86 is basically end of the line. Neat!
I make E23 parts.
10/1984 745i
11/1984 745i
Clean looking ride.
Kris Burrito is in Mesa, he is down the street from ya... and has my old 11/84 745i in Cosmos. You should harass him to plop the M102 into it I gave him...car has BBSs, Bil HDs all around, LSD, rear power seats, no factory rear speakers!
BTW, those 15" wheels on the '86 make ideal spare tires. The E38 'style 5' do not fit in the hole with a 225/50R16.
I make E23 parts.
10/1984 745i
11/1984 745i
Thank you sir! I have some plans for it that may invite the purists to come out and play..... but I won’t release too many details yet!
I’ll have to hunt him down! I’m lucky enough to have an LSD from the factory and the rear privacy screen, a neat feature that’ll go well with some of the “executive” plans I have.
I promise the details are still coming. I’m in the middle of a move and for some reason the girlfriend deemed unpacking and furniture rearranging a priority.
I I have a write up from mye28 that seemed really laid out and relateable with the shared m30. And correct on that starter number! I will hunt your walk through down as well as additional info.
