Results 1 to 8 of 8
Thread: Disable DRL
    Sep 2018
    Nor Cal
    2002 525iT
    Disable DRL
    Hello,
    This is my first BMW and I'm looking for info on how to disable the DRL on my 2002 525iT SW.
    I've been looking for wiring diagrams and forum threads on this and haven't had any luck. Does anyone have any info on how to disable the DRL, or, leads to a thread already out there?
    Thanks,
    Rich
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Your best bet would be to do it with software. Look into getting PA Soft, it's pretty readily available with the cable on eBay. That'll let you code DRL's on and off without messing anything else up. That's how I disabled mine.
    1995 525i 5-speed - Thread
    Sep 2018
    Nor Cal
    2002 525iT
    Thanks for the quick response.
    Is there a relay or fuse for just the DRL's, or do they share the same circuit with other loads?
    Dec 2013
    Chicagoland area
    EXOTICS
    As was said, code them out, get used to this with your first BMW,
    as several functions have the option of coding them active or inactive.
    Dec 2013
    Chicagoland area
    EXOTICS
    Sep 2018
    Nor Cal
    2002 525iT
    Not trying to dismiss the info shared, I'm just trying to gather as much info on the DRL, if there is other options.
    I appreciate the info. Thank you for the link.
    Rich
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    DRL on our wagons use the high beam lights. The control of this feature is adjustable (ON/OFF) by one of the on-board computers thereby you can use a hi-end scanner like Foxwell510 scanner to reset or use one of the lap top BMW applications to turn them off and on. Upgrade the bulb and you are good to go. This was one of the first things I did to my wagon upon purchase. Note: Check the self adjusters to confirm they are NOT broken. Grab the bulb connectors in the rear of the headlamp housing and see if it moves all over the place. If they do then they are broken.
    Question:
    Does your wagon have angel eyes and Xenon low beams? Build Code: 522 Xenon Light. or does it have standard Halogen?
    Note: There is no other way to change the DRL functions without using the in car computer to turn it on or off. There are no "other options" besides cutting the wires PERIOD.
    Note #2: Please use the DIY links to the self help articles listed on the top of this forum, as it will save you lots of Q&A and responding posters time repeating what has been found/repaired/posted multiple times by previous owners over the last 15 years. You are NOT the first person to have problem XXX.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Sonoma Whine Country
    E12, E12, E36, E39
    Not the ideal way to do it, but yes, it can be done. I did a few years ago, on a 02 525it even. In short I put a relay in, switched by the high beams, but the daytime high beam was too low a voltage to turn on the relay. With less than 10 bucks of relays from Amazon, a little wire and headlight terminals from Pick and Pull it worked fine, except for a warning about burned out high beams. I didn't have to cut any wires, just a bit of insulation on the ground. Got into quite a, lets say spirited discussion, too with some comments about skin color even. Eventually I did get them coded out, but until then I wasn't driving around like an a-hole. I had pictures, but they seem to be gone now.
    https://www.bimmerforums.com/forum/s...-so-called-DLR
    98 328is
    02 525ita
    80 528i
    81 528ia
    and decades of owning and driving BMWs
  1. How to disable DRLs in CDN E46
    By eaks in forum Diagnostic Software
    Last Post: 11-11-2011, 04:16 PM
  2. MI Anyone have the ability to disable drl?
    By Mistere311 in forum Great Lakes - US
    Last Post: 09-23-2011, 10:39 PM
  3. Disable DRL
    By NL328i in forum Lighting sponsored by BAVToys
    Last Post: 04-17-2009, 09:10 AM
  4. how to disable DRL
    By homer09 in forum 1983 - 1991 (E30)
    Last Post: 10-10-2008, 09:51 PM
  5. disable drl???
    By ProStreetDriver in forum 1995 - 2001 (E38)
    Last Post: 02-25-2008, 04:32 PM
