Hi,
Before I explain my problem I should note that I know I have needed a new battery and occasionally have to throw my charger on it to get it to start if it has been sitting for several days but I always get full dash and then a click. Last night I did leave the key turned in the ignition.
Today I replaced my oil filter housing which required removal of the alternator. I disconnected the cable from battery before I removed the alternator. Put everything back together and now have no power. All I get when I turn key is the airbag light. Keyfob does not unlock car. No lights, windows, etc. I put the charger on it and after 10 minutes it said it was fully charged.
Is my battery stoned dead or did I do something wrong with the disconnect?
Thank you.
Cams
Check voltage if the battery
_________
1980 320i - Kashmir Metallic - Sold in 1993
1985 535i - Cosmosblau Metallic - Sold in 1995
1985 535i - 1985-06 - Delphin Metallic - Sold in 2016
1983 320i - 1982-09 - Kashmir Metallic - Currently own!
2004 ZHP - 2003-08 - Titanium Metallic - Currently own!
2000 M5 - 2000-02 Titanium Silver - Currently own!
Voltage was low, New battery was the solution.
Thank you
