Results 1 to 4 of 4
Thread: BMW 325i e46 Oil leak
    Aug 2018
    Florida
    2011 BMW 328i
    Exclamation BMW 325i e46 Oil leak
    Goodevening,
    I bought a 2001 325i used, honestly it was trashed, so many problems but I bought this car knowing that. I want to completely change the car around. Its been sitting for a couple months now. I've been in college so I haven't had much time until now. All of my oil has leaked from the car. I checked the valve cover gasket and housing and it doesn't appear to be coming from there. so I checked under the car and it seems like its dripping from where the engine and transmission connects. Dont really know what I need to replace so any advice on what it could possibly be and where I can find the part.
    Thanks,
    TC
    May 2017
    Owings, Md
    1998 328i
    Your in the e36 forum but never the less it could be your rear main seal, between the engine and transmission but it could also be the oil filter housing gasket as the oil migrates back while you drive down the road. I would try this first as it is a much smaller job and is probably due for replacement anyway. The rear main seal is a low parts cost but labor intensive affair that makes sense when you replace the clutch (assuming manual).
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E46 forum
    Aug 2018
    Florida
    2011 BMW 328i
    Much appreciated, sorry I didn't realize my mistake
  1. 2004 BMW 325i (E46) Typical Leaks Locations?
    By McLugnuts in forum 1999 - 2006 (E46)
    Last Post: 07-19-2016, 11:24 PM
  2. 2002 bmw 325i e46 5 speed oil issues and window issues
    By mulcryant in forum 1999 - 2006 (E46)
    Last Post: 06-28-2011, 07:22 PM
  3. 2001 325i E46 Oil Leak
    By risaac325 in forum 1999 - 2006 (E46)
    Last Post: 03-17-2011, 11:32 PM
  4. 2004 bmw 325i E46 M54 engine oli leaking form top
    By opnsesame in forum 1999 - 2006 (E46)
    Last Post: 12-06-2009, 12:18 AM
  5. bmw e30 325i se oil leak
    By dannys bmw in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-08-2006, 11:01 AM
