Results 1 to 9 of 9
Thread: howling noise in engine
    Jan 2013
    Pittsburgh, Pa.
    2001 BMW 330ci
    '01 330ci, 140k...just did a cooling system refresh (radiator, expansion tank new hoses, new tranny thermostat) about 1k ago, Waterpump had already been replaced about 10k ago. Alternator was replaced about 6 years ago. Also recently charged the air conditioner. the car has developed a howling noise and it is occasional. when it does happen, you hear it at start-up and til about 20 mph then it goes away. so, I'm thinking either the waterpump, the alternator or the compressor? would appreciate any help... you guys have always been a great resource, and i need a little direction here
    Dec 2013
    Chicagoland area
    EXOTICS
    Secondary Air Pump/Auxiliary Air Pump
    Should only operate upon cold start-up,
    for a duration of about 30~90sec.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Manual or automatic transmission?
    Jan 2013
    Pittsburgh, Pa.
    2001 BMW 330ci
    automatic. was hoping i'd hear from you!....you've help me so much in the past. thx.
    Jan 2013
    Pittsburgh, Pa.
    2001 BMW 330ci
    actually, the SAP has been growling for awhile...waiting on that one. But this whine/howl is on the other side of the engine??
    Dec 2013
    Chicagoland area
    EXOTICS
    I would assume the power steering pump.
    Have you checked the reservoir for fluid level?
    Inspected hoses for cuts or leaks at fittings?
    Jan 2013
    Pittsburgh, Pa.
    2001 BMW 330ci
    that's a good bet. I did have to add a good bit of fluid. would a bad PSP make that type of noise? You start checking around at all the possible causes, and you realize just how much maintenience/prevent. is needed on these cars when they head for 150k
    Dec 2013
    Chicagoland area
    EXOTICS
    It does make the noise you described when pump is failing or low on fluid.
    You having to top off fluid is verification of that, hopefully no damage was done.
    Now it's time to find location of leak.
    Jan 2013
    Pittsburgh, Pa.
    2001 BMW 330ci
    Thx:
    thinking about replacing the pump and hoses as preventative maintenance.
  1. howling/whistling noise from engine
    By zag in forum 1991 - 1999 (E36)
    Last Post: 08-15-2016, 02:30 PM
  2. Replies: 1
    Last Post: 11-27-2013, 02:35 AM
  3. Need Help howling noise, left side of engine
    By larinah in forum 1996 - 2003 (E39)
    Last Post: 09-07-2009, 09:58 PM
  4. 540i Howl noise from engine, rough idle, smoke on startup
    By EuroFreak in forum 1996 - 2003 (E39)
    Last Post: 07-27-2009, 10:43 PM
  5. BMW Whistle/Howl Noise From Engine?
    By pc tweakz in forum 1983 - 1991 (E30)
    Last Post: 01-19-2006, 04:23 PM
