Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 79
Thread: Cylinder 5 and 6 misfire
  1. #51
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    Quote Originally Posted by sharadn View Post
    how about the caps on the trays? Do these stay with the trays?
    Yes.
    '94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
    '93 325is Coupe, Schwarz, work beater 299k
    '89 325i Vert, Alpine White: 5spd swapped. Sold
    '04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
    '05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
    '85 Toyota LandCruiser: Lifted, gas hog. 205k
  2. #52
    Mar 2015
    Severn MD
    98 328i 10 328i X wagon
    It is at the machine shop right now. He says that the scoring on the cams is not good but he has seen worse and will check out the bottom end with the valves, seats, guides and seals. Based on my experience with compression and leak down tests I think that the rest of the head will be OK once
    the spring has been fixed but he might recommend some refreshing. I think if I could find a decent set of cams and trays it would all work.
  3. #53
    Jun 2010
    NY
    1997 328i
    Did you ask if they are familiar with BMW heads? because they need to know where they typically crack and warp so that they check for those things.
  4. #54
    Mar 2015
    Severn MD
    yes he is familiar with bimmer heads
  5. #55
    Mar 2015
    Severn MD
    I am wondering if I need to look into the cause of the broken spring. Fixing it is not a big deal but I wonder what caused it and if it might happen again. What do you think?
  6. #56
    Jun 2010
    NY
    1997 328i
    Over reving the engine. Have you ever money shifted? ie. missed a gear.
    But I would assume a manufacturing flaw would lead to failure as well.
  7. #57
    Mar 2015
    Severn MD
    No money shifts. I was teaching a kid to drive a standard about 2 months ago and he hit the rev limiter once bit it ran fine after that.
  8. #58
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    I was standing in the garage last year and heard a loud bang. My front passenger spring (H&R OE Sports about 15 years old) just snapped, sitting in the garage.
    It's weird and rare, but it happens.
  9. #59
    Jun 2010
    NY
    1997 328i
    But that could have been it.
  10. #60
    Oct 2016
    Tenerife, Spain
    1997 BMW E36 323i
    Quote Originally Posted by Eric93se View Post
    Hitting 6500rpm redline while accelerating normally shouldn't cause a spring to break, I'd think (otherwise virtually everybody would have broken springs). It can of course happen, but it would be a case of very bad luck.
    A wrong downshift where the engine would rev to say 7000 rpm for a short while, that's something different.
    1997 E36 BMW 323i
    (European) 275k km (171k miles), with following small mods:
  11. #61
    Mar 2015
    Severn MD
    I don't abuse the engine and actually don't drive it very hard. Maybe I have a bit of fun on on/off ramps and hit a bit speed on route 95 but mainly I have it because I like the open air motoring experience. I have never hit 7K during a downshift and I am assuming the rev limiter would take of that.
  12. #62
    Oct 2016
    Tenerife, Spain
    1997 BMW E36 323i
    I think it was just a case of bad luck.. Metal fatigue or something.
    Please note that the rev limiter only helps when you're accelerating. Once the rpm hits 6500 rpm, the DME will stop injecting and stop sending a signal to the coils..
    If you do a bad downshift, the rev limiter does nothing at all to prevent damage. The only thing that saves you from major damage is quickly pressing down the clutch pedal before revs go over 6500 rpm (the engine should take a few more revs for a short while, so there is a bit of margin, but over 7000 rpm it gets problematic very quickly). For example, if you drive +/- 100 mph in 3rd gear (+/- 6500 rpm), and you shift into 2 instead of 4, the engine is toast (unless you un-clutch very quickly when you feel the revs go too high). In 2nd gear, at 100 mph, revs will be at 10,000 rpm more or less. Nothing the rev limiter can do to prevent the damage, as the revs follow automatically due to the rear wheels rotating at a certain rpm, which are then transferred to the engine through the axles, diff, propshaft, gear box and clutch. Stopping the injection and spark plugs from firing won't change a thing.
    1997 E36 BMW 323i
  13. #63
    Mar 2015
    Severn MD
    Thanks for the very interesting information. I really don't think I ever did anything to cause it.
  14. #64
    Jun 2010
    NY
    1997 328i
    And usually money shifting will bend a lot of valve, so your right you probably didn't do it. )
  15. #65
    Mar 2015
    Severn MD
    Yes I was relieved to find a broken spring but no sign of valve to cylinder contact.
  16. #66
    Jul 2011
    Austin, TX
    sharadn, I'm not sure why everyone else is stuck on an overrev. Redlining it ONCE - and at 6500 no less - doesn't come close to counting.
    So many people have their cars chipped to redline at 7000, and then proceed to redline them regularly (and I'm among that group).
    Hitting the limiter at 6500 - once - could not be more of a non-event.
    This is nothing more than a fluke. There's no blame, fault or error.
    I had a valve seat crack and fall out of the head on my Escalade a few weeks ago. Machine shop said he sees it all the time on Hemis, but had never in his life seen it on a Chevy motor. It was just a fluke.
    I'd be relieved you found the problem - and before additional damage was done.
    I'd get a new spring, have that valve checked, all the guides replaced, and I'd find some S52 cams for it.
  17. #67
    Mar 2015
    Severn MD
    Anyone have a sourcer for guides and springs. My machine shop cannot get hold of hi's usual supplier.
  18. #68
    Jun 2010
    NY
    1997 328i
    Pelican parts as well as RMeuropean have both.
  19. #69
    Mar 2015
    Severn MD
    Yeah duh, don't know why I did not think of Pelican. I called Bavauto and they could not supply the guides. The shop is recommending that I replace all 24 valves. I am wondering if it is necessary. This is the first time in my entire life I have had broken valve spring in any car. The shop says that it is so much work to change the head that it makes sense to change them while it is out. Opinions?
  20. #70
    Mar 2015
    Severn MD
    Parts Geek has them also
  21. #71
    Jun 2010
    NY
    1997 328i
    If they're not bent or chipped. Do they know this isn't going to be a race car lol.
  22. #72
    Mar 2015
    Severn MD
    My bad, I was typing too fast and should have said that the shop wants me to replace all the springs not the valves.
  23. #73
    Jul 2011
    Austin, TX
    Valves didn't make a lot of sense to me. I'm still not sure springs make sense unless he's assuming you thrash it all the time and that's why that one did break.
    When I had my head done we replaced the valve guides - that's it. Yes, everything was out, but the other parts were fine.
    Did he say why he wanted to do it (aside from the "while we're in there" argument)?
  24. #74
    Mar 2015
    Severn MD
    The shop is saying that something caused it to break and that all the springs came from the same batch. He says pay me now or pay me later. I talked the BMW mechanic that services my fathers car for a long time now and he says that he has never seen a broken valve spring. It is $354 for a set of springs so it something to consider. The car is 20 years old. Not worth much on the market but worth a lot to me in terms of usage and fun. It is a lot of work to pull the head and all. I will still talk to few other mechanics and see what they think but any other opinions are welcome.
  25. #75
    Mar 2015
    Severn MD
    I just bit the bullet and ordered all new springs. Wow this gets expensive to fix one broken spring. 575 for machine shop, 535 for new head parts 150 for head gaskets around 125 for tools. Closing in on 1500 and that is with me doing the labor. Still waiting to get a cost on a good set of cams and lifters. At lease when I put it back together I will know it is good. Whew....
  1. Cylinder 1 Misfire Detected and Rough Idle, what can it be?
    By ADVANT123 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-23-2006, 12:14 PM
  2. How can you test if a cylinder is misfiring?
    By Strahan in forum 1995 - 2001 (E38)
    Last Post: 04-11-2006, 07:40 PM
  3. Cylinder #5 misfire (PO305) - where to start?
    By bmwlovr in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-09-2006, 05:12 AM
  4. Cylinder #8 Misfire
    By MattDewalt in forum 1996 - 2003 (E39)
    Last Post: 07-01-2005, 09:25 AM
