Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Thread: Piping above subframe with a/c.
  1. #26
    Sep 2008
    selah WA
    1996 m3
    Quick update: 2.5” fit without to much issue. I may oval out the section under the a/c but current it’s not hitting. Really there is only one way for this to work so I imagine what I’ve down is as others would have expected. Straight out turbo with 90 degree behind a/c then wiggle around sway bar an hit the intercooler. Total of 3 couplers will be used on the hot side of the intercoooler. All the pipe was from a generic amazon intercooler kit. I had enough to do all the piping.
    I was also able to keep a 3” intake pipe for the turbo.
  2. #27
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Looking good! I wonder if this is possible with the Steed?
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  3. #28
    Nov 2013
    VA
    E36
    Good work. Looks very similar to my setup with the spa manifold.
  4. #29
    Sep 2008
    selah WA
    1996 m3
    Quick update. Found if I dropped the sway bar prior to install I can actually get the entire piece in one shot. This saves me from having a coupler in the middle.
  5. #30
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Trimmed 45-45-90-90?
  6. #31
    Sep 2008
    selah WA
    1996 m3
    Yep with some space between. When you say it like that I feel I’ve put to much time into this project.
  1. size of pipe for subframe bushing tool?
    By draccent in forum 1983 - 1991 (E30)
    Last Post: 07-13-2009, 10:10 PM
  2. Charge pipe over subframe guys, what are your iats like??
    By PedroBMW in forum Forced Induction
    Last Post: 11-04-2008, 08:07 PM
  3. Anyone have pictures of a charge pipe over the subframe?
    By Bromaguire in forum Forced Induction
    Last Post: 03-26-2008, 09:11 PM
  4. IC piping that goes over the subframe
    By Don Nguyen in forum Forced Induction
    Last Post: 01-16-2008, 01:10 AM
  5. Replies: 1
    Last Post: 11-28-2006, 01:56 PM
