Results 1 to 25 of 31
Thread: Piping above subframe with a/c.
    Sep 2008
    selah WA
    1996 m3
    Hello, looking for input on those with oversubframe piping. Did you go around the a/c and back under the sway bar or under the a/c. I’m lost on how to get a 2.5” pipe between a/c and steering rack. I have to replace my motor mount. Is it possible my issue is stock motor mounts, do aftermarket poly mounts sit higher?
    Another question. After I welded a vibrant 90 to my gtx35r with spa manifold I cant find room to get a v band clamp on the intake turbine like I had planned. What couplers are people using that don’t melt? Anyone try making a heat shield that mounts to exhaust studs? I could weld a slight jog into the pipe under the manifold so I had room for the v band clamp. but it would make install a pain.
    Jan 2016
    Littleton, Co
    E36 S52 M3/4/5 Cos. Blk.
    The pipe have to go between the rack and ac, it'll fit on he very inside edge of the tie rod boot, and goes above the sway bar. But I had to jack the engine up significantly to fit it there, then set it down. I bought my pipes though, surely it'll take some trial and error if you're making them.. don't have any issues with melting on the silicone coupler. T bolt clamps on the charge pipe/compressor outlet if you clock the turbo correctly. What a huge pita to install and set all this up correctly... took me forever even with a turbo kit because of the lack of space... good luck with making it, it's going to take some time I'm sure. I probably have pictures or can take some . Pm me if you want.
    '97 BMW M3/4/5, Cosmos Black.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Most over the subframe kits with AC use 2.0 pipe. Let us know how you do with the 2.5.
    Sep 2008
    selah WA
    1996 m3
    I can make everything fit 2.5” if I figure out the a/c and use a coupler.
    Recently 3D printed snap together mandrel bends to mock everything which speeds things up.
    Apr 2017
    NJ, USA
    '07 335I 6MT, '01 330i
    Looking forward to seeing how you sole the issue- I'll be trying to run above subframe piping on my e46 eventually. I'm currently running no front sway bar too.
    Keep it simple: half gutted '01 330i, welded diff, BC coils, SLR Super kit
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    I made it work with a 2.5" pipe but I can't upgrade my sway bar.... It doesn't touch the sway bar anymore with the new motor mounts I got.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
    Sep 2008
    selah WA
    1996 m3
    Quote Originally Posted by somebody5788 View Post
    What motor mounts did you have and transition to?
    Nov 2008
    Indiana
    Quote Originally Posted by lisnowboarder View Post
    I had stock mounts with like 12000 miles on them. I went to the Vibra-tech motorsport mounts.
    Mar 2012
    Renton, Wa
    98 m3
    I have 3” over the subframe :devilook:
    Had to do a custom power steering cooler.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Jun 2005
    New England
    If that is with AC, take a picture for us. I was considering 3 inch oval piping but think I will have to go under. If no AC then there is obviously lots more room for piping.
    Feb 2017
    Raleigh, NC
    1998 M3 643whp
    [QUOTE=lisnowboarder;30095595]Hello, looking for input on those with oversubframe piping. Did you go around the a/c and back under the sway bar or under the a/c. I’m lost on how to get a 2.5” pipe between a/c and steering rack. I have to replace my motor mount. Is it possible my issue is stock motor mounts, do aftermarket poly mounts sit higher?
    Can you post more pics of your setup? Welding tight elbows to the compressor housings can really choke the flow. I know there isn't enough room to fit much of anything under there, but since you seem to have access to 3Dprinting, you should try to also print something like this:
    This design gives you the tight radius, but allows more cross sectional flow through the elbow and chokes far less. If you have SolidWorks, I would try to surface loft the transition through the obstacle course and print it out. Once you get something that works, there are several companies that can metal coat (dip process) your FDM parts to surface coat them in metal. It really improves the strength and heat resistance of the 3D printed parts. People really underestimate how much HP and spool there is to gain from a piping system that has been optimized without any choke points. The sad thing is that just about every system for E36s has multiple choke points due to how difficult packaging is.
    Intake V-band couplers can be tough to make work as the engine moves around relative to the IC. Just make sure you get one that takes standard O-rings as they are much easier to service vs a flat gasket design. T-bolt / silicone couples CAN work well up to about 25-30psi, but require smooth pipes to reliably seal against. The wrinkle powder coat absolutely destroys sealing capability, unless you mask 2" on each end of the pipe. For Vband flanges, you will gain in max PSI capacity and they flow better than couplers, but your alignment precision goes way up. As soon as the engine starts moving around, they can break the aluminum weld (or the seal) if you don't have enough compliance in your piping. They aren't cheap either.
    If this is just a street car: I'd advise you to just try to minimize your cold side couplers to 4-5 if possible: 1 on turbo compressor, 1 on IC inlet, 1 on IC outlet, 1 between IM, 1 on IM.
    Mar 2012
    Renton, Wa
    98 m3
    Yeah it’s with ac.
    I go forward to the ac compressor. above the subframe and around below the compressor. You have to drop the ps cooler. Then over through the spot in the sway.
    1989 535i - sold
    Jun 2005
    New England
    You mean the PS trombone pipe? Are you running your intake up between the mainfold and framerail to behind the headlight? Mine is in the above the subframe space going to behind the fog light.
    busterhax's Avatar
    busterhax is offline Y̝͎̘̍́ͣ̉͑̿̆Ō͎̼̺̬̒ͯ̃̇͗̂ U͈̖
    Jun 2006
    NYC
    e36
    I run a gt3582r with t04e compressor housing so I have a 2” out.
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Vollosso can you post a picture of your piping?
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by 3literheater View Post
    I don’t have one on hand. You need to wrap under the ac compressor and above the power steering. From there over and around to the intercooler.
    I run this with a 4” inlet and a underpanel that mounts vertically so there’s room there.
    1989 535i - sold
    Oct 2005
    Northern California
    I have thought about making a custom AC bracket to space the compressor down a little bit. And if that bracket was made of steel it would be a lot smaller and provide more room for the over the subframe piping.
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
    Mar 2012
    Renton, Wa
    98 m3
    Last time I had the motor out I did modify the bracket to make life easier.
    1989 535i - sold
    Jun 2005
    New England
    Mine is lowered with an adapter plate. This required a different belt and a custom lower radiator neck for clearance (I have a mishimoto z3s54 rad that is thicker).
    Oct 2005
    Northern California
    Got a picture of this adapter plate?
    I assume you no longer have a tensioner?
    Jun 2005
    New England
    I have the tensioner still. Adapter plate is just an aluminum plate bolted to the blockand the ac bracket bolts to it. So I am spaced out a little in addition to down. I forget where I bought it but supposedly it was designed for this. I bought it 6-7 years ago.
    Oct 2005
    Northern California
    Damn I've never seen anything sold like that. Much easier to buy than build.
    Wish you guys had build threads or pictures.
    Jun 2005
    New England
    I think I got it from speed force racing, which did turbo kits for these cars 10 years ago. My garage won’t be done for a month but I can take a picture then. I’d guess it’s a 5x7 plate about 3/4 thick that bolts to the stock ac mount holes and has 2 rows of holes drilled down the face so you can bolt the stock Ac bracket to it higher or lower. I actually found it was not that useful because I had to Modify it. I could have made something.
    Nov 2013
    VA
    E36
    Used vibrant 90 degree elbow with reinforced, orange silicone coupler. I then heat wrapped the coupler for peace of mind. Pics are from preliminary mockup but the final product was easily doable with 2.5" piping...
    Apr 2006
    Minnesota eh?
    86 325es
    [QUOTE=wgknestrick;30098088]
    I’ve been working in the 3d printing industry for about 10 years. There is only a couple printing materials available that would handle the temp, oils, and UV in the long term and they are very expensive. This is definitely something your not going to successfully build on a desktop home printer.
  1. size of pipe for subframe bushing tool?
    By draccent in forum 1983 - 1991 (E30)
    Last Post: 07-13-2009, 10:10 PM
  2. Charge pipe over subframe guys, what are your iats like??
    By PedroBMW in forum Forced Induction
    Last Post: 11-04-2008, 08:07 PM
  3. Anyone have pictures of a charge pipe over the subframe?
    By Bromaguire in forum Forced Induction
    Last Post: 03-26-2008, 09:11 PM
  4. IC piping that goes over the subframe
    By Don Nguyen in forum Forced Induction
    Last Post: 01-16-2008, 01:10 AM
  5. Replies: 1
    Last Post: 11-28-2006, 01:56 PM
