Results 1 to 4 of 4
Thread: Rear Window Shade Direction
    radlaw's Avatar
    radlaw is offline SoCalEights Member BMW CCA Member
    Feb 2010
    Poway (San Diego), CA USA
    1995 BMW 840Ci
    I installed a rear window shade in my 95 840. After bolting it down and making all connections, when I turn it on, it starts and suddenly stops. It goes horizontally in direction of the rear window, which stops it, instead up verticallly up the window. I have not installed the shelf yet. What did I do wrong?
    radlaw's Avatar
    Feb 2010
    1995 BMW 840Ci
    OPPS, found the problem: I was putting it in backwards. Duah.
    radlaw's Avatar
    Feb 2010
    1995 BMW 840Ci
    Finally got 'er done. I have finished completely re-doing the entire rear shelf including adding a shade. And it works, well 90% works. I'll "Leave well enough alone"! This was a year-long project.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    wow, took a long time, I remember I sent you the steel gear and the enforcecment bush for the sunshade gear last year August, congrats.
  1. '97 740iL Soft Brakes & Rear Window Shade
    By RyanIL in forum 1995 - 2001 (E38)
    Last Post: 04-27-2008, 09:28 AM
  2. rear window shade part number
    By gameeffect in forum 1995 - 2001 (E38)
    Last Post: 06-03-2007, 09:20 AM
  3. rear window shade
    By bman10 in forum 1988 - 1996 (E34)
    Last Post: 03-20-2007, 08:26 PM
  4. Rear window shade
    By zx7rhitch in forum 1991 - 1999 (E36)
    Last Post: 05-21-2006, 11:27 PM
  5. automatic rear window shade problem
    By sxschin in forum 1988 - 1996 (E34)
    Last Post: 03-18-2004, 12:34 AM
