Results 1 to 2 of 2
Thread: Dinan Supercharger kit (Including ECU) - E36 M3 S52
    Jun 2016
    Colorado
    M3
    Dinan Supercharger kit (Including ECU) - E36 M3 S52 *Price Reduced*
    Sold
    Bought this kit over a year ago from these forums, never installed it and selling it since I am now getting ready to sell my E36.
    The only difference is now the kit will include all bearing and seals needed for a full rebuild.
    __________________________________________________ __________________________________________________ _______________________________________
    Information below copied directly from the FS post I purchased this kit from, and link to original FS post:
    https://www.bimmerforums.com/forum/s...nger-Available
    "I am in process of my S54 swap so its time to let go of my Dinan Supercharger kit. The kit was installed by a BMW dealer in Southern California. The kit has about 40K miles on it. There is no visible play in the supercharger shaft and the wheel looks to be in perfect condition. I would however suggest a rebuild (bearings and seals) as preventative maintenance prior to installation but that is up to the new owner."
    The kit will include everything listed below:
    S52 ECU with Dinan Software
    Vortech V2 S-Trim Supercharger
    Dinan Main Charger Bracket w/Hardware
    Dinan Upper Charger Bracket w/Hardware
    Dinan Lower Charger Leg Bracket w/Hardware
    Dinan Lower Charger Leg Spacer
    Dinan Rear Charger Leg Brace w/112mm Bolt
    Dinan M10 Supercharger Mounting Stud (D673-10219)
    Dinan M10 Mounting Bushing (D612-0310)
    Dinan M8 Supercharger Mounting Stud (D673-0116)
    Dinan M8 Mounting Bushing (D612-0309)
    Dinan Supercharger Oil Feed AN Fitting
    Dinan Modified OBDII Oil Dipstick Tube
    Dinan Crank Pulley (D315-0545) w/bolts
    Dinan Supercharger Pulley (D315-0306)
    Belt Tensioner Pulley (36094)
    Dinan Supercharger Belt (D862-4217)
    Dinan Air Filter (D403-0300)
    Dinan Silicone Elbow (D340-0720)
    Dinan Silicone Elbow (D340-0660A)
    Dinan Intake Side Metal Elbow (SC to MAF)
    Dinan Accordion Couplers [Qty 2]
    Dinan Intake Side Metal Elbow (MAF to Air Filter)
    Bypass Valve (0280142102)
    Dinan Silicone Elbow ? Throttle Body (D340-0670)
    Dinan Boost Tube Metal
    Dinan/Lucas 28.8# Injectors (D1720BA)
    Dinan clutch Fan Spacer
    Brake Booster Hose w/Dinan Vacuum Tee
    Dinan CCV Setup
    Alternator bolt
    Below are the bearings and seals included:
    Jun 2016
    Colorado
    M3
    Sold
  1. Dinan Supercharger kit (Including ECU) - E36 M3 S52
    By ErikV in forum Forced & Chemical Induction Parts
    Last Post: 09-06-2018, 09:27 AM
  2. Dinan Supercharger kit (Including ECU) - E36 M3 S52
    By ErikV in forum Engines, Performance Parts & Software
    Last Post: 09-01-2018, 05:45 PM
  3. SUPERCHARGER KIT FOR EITHER E36 M3 OR Mcoupe/roadster.
    By McoupeBobby in forum BMW Parts Wanted
    Last Post: 04-20-2007, 10:32 PM
  4. Dinan Supercharger for OBD 1 e36 M3. Work on OBD 2??
    By jakeg in forum Forced Induction
    Last Post: 10-27-2006, 10:37 AM
  5. How much MPG does a Dinan Supercharger get for an e36 M3?
    By D Unit in forum Forced Induction
    Last Post: 03-31-2005, 03:22 PM
