Results 1 to 5 of 5
Thread: Sway bar tech question
    Aug 2009
    CA
    E36
    On the E36 I have looked at lots of sway bars and I am wondering some have a bigger dip than others. Will this make the bar be more or less stiff or the same? of course as long as they are the same mm.
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    I think the longer the bar, the softer is it, given all other variables are the same (bar diameter, hollow, wall thickness, etc). But, maybe only the lever length and the horizontal distance matters since the stiffness comes from the twisting resistance .... good question!
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Charlotte NC
    11 128i
    The shallow style came on the 4cyl cars, deep version for the 6cyl. When on jackstands, at full droop, the shallow swaybar will rotate and could hit the front of the 6cyl oil pan. Ran into this issue when I did my engine swap, check out the thread below for pics.
    https://www.bimmerforums.com/forum/s...ar-on-M3/page3
    11 128i Space Gray slicktop
    13 WK2 Deep Cherry
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by dirtdiggler View Post
    Same diameter bars, the longer bar (with larger 'dip') will be less stiff. A bar will bend in torsion and/or longitude. Effectively, the longer bar is a longer spring of the same diameter, and hence less stiff. That's what makes sense to me, anyway! Yea, good question!
    Aug 2009
    CA
    E36
    The shorter bar being more stiff makes total sense to me. And I am running a different engine in my car so clearence is not a problem.
    On another note it looks like where the end links attach are the M3 bars longer so its more vertical for the link?
  1. Rear sway bar: Size question
    By Preppy in forum MINI (Cooper & Cooper S)
    Last Post: 07-30-2005, 08:27 PM
  2. Front Sway Bar Link Question
    By Ken's 323is e36 in forum 1991 - 1999 (E36)
    Last Post: 12-18-2004, 06:30 PM
  3. sway bar stiffness questions
    By M42 Technik in forum 1991 - 1999 (E36)
    Last Post: 02-10-2004, 01:33 AM
  4. Sway Bar Bushing Question
    By mredwin25 in forum BMW Parts For Sale
    Last Post: 08-26-2003, 08:31 PM
  5. Sway Bar Link Question
    By MojoMoto in forum 1991 - 1999 (E36)
    Last Post: 07-02-2003, 01:49 AM
