Results 1 to 3 of 3
Thread: P0304 Check Engine Light
    Aug 2018
    oil city, pa
    2013 bmw 528i x drive
    2013 BMW 528i X Drive 59K miles
    Check Engine Light (CEL) came on today and OBD tool said P0304 Cylinder 4 Misfire Detected.
    Cleared the code and drove hard for about 15 - 20 minutes and CEL did NOT come back on.
    Could the P0304 be a one off?
    Since it has not come back on I do not think I have a bad ignition coil or spark plug.
    As long as it stays off OK to just forget about it?
    Thanks.
    Jun 2008
    Dallas, Texas
    '14 550/M, '03 540/M
    I thinking clearing a code doesn't necessarily clear the problem. after a certain number of miles (around 50'ish) if there's a problem the code will re-appear. A bad ignition coil, spark plug, or a faulty or clogged injector would cause that code.
    Mar 2014
    AL
    X5
    Replace the ignition coil on cylinder 4. If the plugs are still good, just clean them and reinstall.
  1. Fuel Cap & Check Engine Light
    By jaramill in forum 1992 - 1999 M3 (E36)
    Last Post: 05-10-2016, 03:50 PM
  2. help: check engine light
    By m3fanatic97 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2001, 06:33 PM
  3. Check Engine Light
    By FatBoyM in forum 1992 - 1999 M3 (E36)
    Last Post: 04-11-2001, 03:08 PM
  4. FYI - Check Engine Light (regarding fuel)
    Last Post: 04-09-2001, 01:55 AM
  5. A tip for curring Check Engine Light
    By ///M in forum 1992 - 1999 M3 (E36)
    Last Post: 03-30-2001, 01:25 PM
