Hey All, I'm considering the VF kit for my '98 540i at 130k miles. Compression numbers are all 184-195, so a max of ~5% difference between cylinders. Is that within what you'd consider "within normal limits for FI?"
Full reseal was finished about two months / 1000 miles ago. Also, new timing chains, noisy Zionsville full cooling kit, UUC clutch and flywheel/ M5 diff / prop-shaft / 540 axles combo.
Yeah that’s fine. Could be better really but most oem motors are about there.
1989 535i - sold
1999 M3 Tiag/Dove - sold
Zack, change your location in your location. LOL, you moved from redneck county to greenneck county. I lived 2 years in Dothan/Enterprise. My neighbor was a moonshiner and made $4k a week and that was many, many years ago.
22RPD Tuning '95 540i/6 custom turbo mit Borg Warner S400sxe/Rebello Racing 4.9L M62/JE pistons/Arrow rods/custom cams/S62 crankshaft/Darton sleeved/Focal custom stereo
Porsche 996 Turbo Evosport GT 700-[700hp]-my daily
Thanks for your replies and feedback.
Jimmy, I've always been in a redneck county of Pennsyltuckey; I think you may have me confused with someone else. Your engine setup sounds...bananas, in the best way
LOL, Vollosso is also Zack. He is installing a custom turbo kit for my M62. Your compression was similar to mine. VF kits are somewhat low boost levels, 6-9 psi I think. My psi was around 8 and I had 550 rwhp on a Mustang dyno and 614 rewhip on a "make your own numbers" RMS dyno.
