Results 1 to 9 of 9
Thread: Dinan Supercharger kit (Including ECU) - E36 M3 S52
    Jun 2016
    Colorado
    M3
    Dinan Supercharger kit (Including ECU) - E36 M3 S52 *Price Reduced*
    Sold
    Bought this kit over a year ago from these forums, never installed it and selling it since I am now getting ready to sell my E36.
    The only difference is now the kit will include all bearing and seals needed for a full rebuild.
    __________________________________________________ __________________________________________________ _______________________________________
    Information below copied directly from the FS post I purchased this kit from, and link to original FS post:
    https://www.bimmerforums.com/forum/s...nger-Available
    "I am in process of my S54 swap so its time to let go of my Dinan Supercharger kit. The kit was installed by a BMW dealer in Southern California. The kit has about 40K miles on it. There is no visible play in the supercharger shaft and the wheel looks to be in perfect condition. I would however suggest a rebuild (bearings and seals) as preventative maintenance prior to installation but that is up to the new owner."
    The kit will include everything listed below:
    S52 ECU with Dinan Software
    Vortech V2 S-Trim Supercharger
    Dinan Main Charger Bracket w/Hardware
    Dinan Upper Charger Bracket w/Hardware
    Dinan Lower Charger Leg Bracket w/Hardware
    Dinan Lower Charger Leg Spacer
    Dinan Rear Charger Leg Brace w/112mm Bolt
    Dinan M10 Supercharger Mounting Stud (D673-10219)
    Dinan M10 Mounting Bushing (D612-0310)
    Dinan M8 Supercharger Mounting Stud (D673-0116)
    Dinan M8 Mounting Bushing (D612-0309)
    Dinan Supercharger Oil Feed AN Fitting
    Dinan Modified OBDII Oil Dipstick Tube
    Dinan Crank Pulley (D315-0545) w/bolts
    Dinan Supercharger Pulley (D315-0306)
    Belt Tensioner Pulley (36094)
    Dinan Supercharger Belt (D862-4217)
    Dinan Air Filter (D403-0300)
    Dinan Silicone Elbow (D340-0720)
    Dinan Silicone Elbow (D340-0660A)
    Dinan Intake Side Metal Elbow (SC to MAF)
    Dinan Accordion Couplers [Qty 2]
    Dinan Intake Side Metal Elbow (MAF to Air Filter)
    Bypass Valve (0280142102)
    Dinan Silicone Elbow ? Throttle Body (D340-0670)
    Dinan Boost Tube Metal
    Dinan/Lucas 28.8# Injectors (D1720BA)
    Dinan clutch Fan Spacer
    Brake Booster Hose w/Dinan Vacuum Tee
    Dinan CCV Setup
    Alternator bolt
    Below are the bearings and seals included:
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    For any interested buyers, I can help restore this to like new.
    Jun 2005
    Chicagloland
    99 Estoril Blue M Coupe
    Do want, have to do some research to see what I need to make it fit in s52 z3m. Brb
    Jan 2006
    Oakhurst, CA
    Quote Originally Posted by chemicalviper View Post
    Everything fits except you need the Z3M specific intake side parts. Charger to air filter portion. I happen to have that Z3M section if you are serious about buying this guy’s charger.
    Jun 2016
    Colorado
    M3
    Sold
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    I have a 10psi Dinan setup with RMS cooler I’ll be selling. It’s ready to go, but I bought a Carrera yesterday so the M3 will be departing soon.
    (Not trying to highjack the thread just though if you missed out on this one, mine might interest you)
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    Sent from my iPhone using Tapatalk Pro
    Oct 2007
    Kirkland, WA
    M3, '69 911 2.8SS, '70 9
    Adam,
    What are you looking to get for your Dinan/rms setup?
    Email me at:
    Brooke at SBMC dot com.
    May 2017
    Boulder, CO
    1997 BMW M3 Sedan
    I should add, I had my blower painted VHT black and replaced all fasteners with Stainless bolts. so it's pretty today
  1. WTB - SUPERCHARGER KIT 4 Auto e36 m3
    By supaBang in forum Race Cars & Track Parts
    Last Post: 01-26-2009, 08:45 PM
  2. E39 Dinan CF Intake WORK ON E36 M3 S52?
    By MTRD3 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-16-2008, 09:57 PM
  3. SUPERCHARGER KIT FOR EITHER E36 M3 OR Mcoupe/roadster.
    By McoupeBobby in forum BMW Parts Wanted
    Last Post: 04-20-2007, 10:32 PM
  4. Dinan Supercharger for OBD 1 e36 M3. Work on OBD 2??
    By jakeg in forum Forced Induction
    Last Post: 10-27-2006, 10:37 AM
  5. How much MPG does a Dinan Supercharger get for an e36 M3?
    By D Unit in forum Forced Induction
    Last Post: 03-31-2005, 03:22 PM
