Results 1 to 11 of 11
Thread: I believe my oil filter housing is leaking.
    Apr 2018
    South Carolina
    2006 325ci
    06 325ci
    I’ve been leaving a wet spot. I pulled the plastic cover off and it seems to be coming from the oil filter housing gasket. It’s coming from the front left of the engine and running down and blowing back on everything.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Very common issue. It’s a bit of a PITA but it’s doable. Make sure you buy the new gasket from the dealer. Aftermarket gaskets are a no no.
    Apr 2018
    South Carolina
    2006 325ci
    Quote Originally Posted by MarcoZandrini View Post
    Really? They can’t even get a gasket right?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Hey, it’s German. They build motors that weep. Try a Brit car. They stop leaking oil when the oil ya gone!!
    A little tip: once you’ve got the housing out, clean the mating surfaces with CRC Brake Clean and allow everything to dry. Then put a veeeeery thin bead of high temperature rtv on the outermost mating surface of the housing. Allow it to dry for at least an hour. Then carefully reassemble with the new gasket from the dealer. Make sure the bolts go in their correct holes. Tighten the bolts using fav star oattetn. Torque them to the correct value.
    Apr 2018
    South Carolina
    2006 325ci
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    That should read “tighten the bolts using a star pattern.” Tighten them gradually.
    You're welcome.
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    NOt to mention use Lotite blue or green. NOT Red!
    Rule of thumb...antiseize or loctite on everything.
    Red is strongest, might have to use heat to get it off.
    Blue is medium, works for nearly everything.
    Green is weakest, to be honest, I've never used it.
    Loctite or Permatex also makes a sealant (white paste like) for bolts that go through into water jacket.
    Apr 2018
    South Carolina
    2006 325ci
    Quote Originally Posted by SloopJohnB View Post
    I like to use blue loctite.
    How many bolts go through the water jacket?
    May 2010
    Honolulu, Hawaii
    '73 E9, '94 E34, '02 E46
    Helped a pal with an X5 (similar motor) and it turned out to be the oil line at the banjo bolt. When you take off the oil line, the crimped end fitting should be tightly bound to the hose, not swiveling around. But having gone that far we also replaced the gasket.
    Charlie
    Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
    CT
    E28, E32, E39, E53, E90
    If you do the oil filter housing gasket, change the vanos oil line as well. It's another common source of leaking and is inexpensive "while you're in there".
    Here's the OFHG for M54 video DIY guide I made recently, airbox is different on the E46 but the rest is pretty much the same basic M54 stuff
    https://www.youtube.com/watch?v=nYCgnUkDvJk
    Sep 2008
    Sandy, Oregon
    2002 330Ci, 1995 325is
    If you think it's leaking, it probably is.
  1. M50 Oil Filter Housing Gasket leaks after replacement
    By uberSteuer in forum 1991 - 1999 (E36)
    Last Post: 05-10-2014, 10:19 AM
  2. E36 Oil Filter Housing is Leaking !
    By clean328 in forum 1991 - 1999 (E36)
    Last Post: 12-03-2013, 03:28 AM
  3. m52 Oil filter housing still leaking
    By Jontsu in forum 1991 - 1999 (E36)
    Last Post: 04-10-2013, 09:11 PM
  4. Oil filter housing gasket leak? Fear not.
    By Neasy 92 525i in forum 1999 - 2006 (E46)
    Last Post: 02-09-2011, 10:16 AM
  5. Oil filter housing gasket leak
    By fishfeet in forum 1991 - 1999 (E36)
    Last Post: 11-25-2008, 06:03 PM
