My 1999 Z3 trunk latch will not latch closed. Gently or slam it closed same result, will not latch closed. Purchased a used latch hoping that would fix it but it did not. Any ideas? Thanks
I am sure this is a dumb question, but did you make sure that the latch was “open” so it would accept the metal strap mounted at the base of the trunk?
Greg
Tally Ho
http://wcwebs.net/johnson
1988 O'Day 322 sailboat - (unlimited mpg)
2000 BMW Z3 M Roadster (25 mpg - but who cares)
2019 Subaru Outback
(30+ MPG)
Not a dumb question, it got me thinking. The latch is open but the piece attached the car that actuated the latch on the lid was not striking the latch. So I adjusted the piece on the car, inside the truck, up and that fixed it. The piece was worn from years of opening and closing. Embarrassed I did not notice this, I purchased the used latch when all I needed to do was adjust. Thanks!!
Check that the sheet metal in the trunk lid is not cracking at the bolt holes that hold the latch
Tally Ho
2019 Subaru Outback
(30+ MPG)
