Results 1 to 4 of 4
Thread: 2011 BMW 535 (F10) Overheating
    Aug 2018
    toronto, Ontario, Canada
    2011 BMW 535i
    Unhappy 2011 BMW 535 (F10) Overheating
    My car is overheating because my radiator fan doesnt start when the car overheats. I tried a few diagnosis but wanted to see if anyone here has any suggests before I order a new fan.
    Here is what I found so far:
    1. The Fan works when I turn the AC on
    2. The coolant flows past the thermostat so that should rule out thermostat or water pump issues.
    3. When I unplug the fan (AC off) after the overheat warning and plug it back in, it turns on for a second and then turns off.
    4. I inspected the fuses and they seemed ok.
    I am not convinced that the fan is bad because it works with the AC. The only thing I didn't test yet is the temp sensor with I assume should be working because it triggers the thermostat.
    The fan at Canadian dealerships is soo expensive ($1900 at the dealership and about $1000 aftermarket) so I want to be sure thats the problem before I order it. Please help!
    Ayton ON
    E430 P911 Denali XL
    I might be a little late to help but it's my understanding that the water pump is bad in these models.
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    I think the water pump is also electric.
    Oct 2018
    Canton, MI, USA
    2012 BMW 535i
    Were you able to find out the issue? I am having similar problem. My issue is the fan turns on every few seconds and stops right away. Even first thing in the morning. The engine doesn't heat up, the water flows and I can see it dropping in the coolant reservoir. I am assuming the problem could be Radiator fan sensor or the coolant sensor. If anyone has any idea, please let me know. Thanks
  1. F10 WTB 2011 or newer F10 535 manual trans
    By pfunke1 in forum 5 series & 6 series
    Last Post: 02-10-2018, 10:10 AM
  2. 2011 BMW 535 - Power Issues?
    By bmw14449 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-28-2017, 09:58 AM
  3. 2011 BMW 550i F10 Acceleration Lag/Stutter
    By fazderbazder in forum 2011-2016 (F10)
    Last Post: 08-26-2016, 08:18 AM
  4. 2011 BMW 535 won't start
    By Soka in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-18-2016, 08:53 PM
  5. 2011 bmw 528i f10 where is the fuel pump relay?
    By kentuckynet in forum 2011-2016 (F10)
    Last Post: 07-28-2015, 03:35 PM
