Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 87
Thread: Mr Turbo Thad rides off into the sunset
  1. #26
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Thanks for the links Thad. I'm gonna have to wait to see what I have for hood clearance.
    This would look so sweet and sound killa on my LS3.
    https://www.ebay.com/itm/Chevy-GM-LS...8AAOSwHMhbpIWY
    Not that I know squat about TIG'ing (still learning but getting better) I've been using my Burns-Omatic torch to heat up the thick stainless exhaust flanges before welding the thin exhaust tubing to the flange. Doing this so I don't have to rely on the TIG to supply as much heat so I don't melt a hole thru the thin tubing.
  2. #27
    DeWitt, Michigan
    '97 540i/6, '97 328i
    That would be WICKED Jim!!!
    And regarding the welding, I think if you have a really sharp point on your tungsten but at rather a blunt angle, you'll be able to direct the heat into the flange first if you want to skip the pre-heating step. But having said that, I believe there is no wrong method if the results are what you wanted them to be.
  3. #28
    JimLev's Avatar
    Sundance Mesa, NM
    I seem to always have problems seeing where the tip is at.
    Second problem is keeping the tip out of the puddle.
    I found a bunch of 102mm TB on eBay.
  4. #29
    DeWitt, Michigan
    2.5 reading glasses from Walgreens are the ticket Jim!!
    That and the slight lift of the tungsten right at the moment that you add filler. The puddle will rise up and jump onto the tungsten if you have a nice tight arc and don't lift it slightly when you dab. This is about 20x as true when doing aluminum.
  5. #30
    JimLev's Avatar
    Sundance Mesa, NM
    Good info Thad. Will get some of the 2.5 cheater specs.
  6. #31
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    That is definitely what she said.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  7. #32
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Where is Manny? figured he grab a hold of that one.
  8. #33
    Minneapolis,MN
    2003 M5, 2014 535i
    Thad, I’m curious why you prefer to assemble the ECU board vs. buying one that is assembled ( assuming that’s an option).
    2003 M5 LSx l 6 Spd Manual l 4.10 LSD
    Build Thread
    The chassis must always be regarded as a means to an end and never as an end itself
  9. #34
    Mar 2010
    Quote Originally Posted by Schitzo View Post
    Cheapass bitch izwhy.
    2003 M3CicM6 TiAg
    Former:
  10. #35
    DeWitt, Michigan
    HA!! That's definitely one of the most powerful reasons!
    Other than that though, it's what I'm comfortable with, and what has always worked for me. There's unlimited customizability, and if some component messes up, I can fix it.
    Aside from all of that, though, if I had known that this MS3X was going on an LS engine, I might have looked at a gold box, or one of the other MS3X equivalent pre-built units that are PnP for an LS wiring harness. Some guys have had issues with the MS3 Ultimate and Evo prebuilts from DIY Autotune, but a lot of guys haven't. I just dunno... I usually get my next kit on black friday when they're 10% off, so there is a big price difference...
  11. #36
    Minneapolis,MN
    2003 M5, 2014 535i
    Quote Originally Posted by tptrsn View Post
    Wondered if you were doing it for the sake of customization. What's different between the one you built for the M62 and this one? Did you have to add drivers for the pushrods
    I've been reading quite a bit about MS3 and part of me actually thinks I should have gone with it instead of the GM ECU I currently use. May be on the next project.
    Keep the updates coming.
    Build Thread
  12. #37
    DeWitt, Michigan
    I did have to add the pushrod drivers, but on the upside I was able to delete the timing chain guide circuit and the alusil circuit. Kind of a wash overall.. Lol
  13. #38
    Mar 2010
    heh heh.
    2003 M3CicM6 TiAg
    Former:
  14. #39
    DeWitt, Michigan
    Got a new pup that is taking up quite a bit of my time, but I have been able to make a bit more progress on the LRS. Hoping to **MAYBE** be able to make the Halloween Bash with it:
    Coolant tubes for hackjob rear mount radiator:
    Chopped out the bottom of the spare tire well:
    Lol...
    Love this car! Hahaha..
  15. #40
    Mar 2012
    Lansdale, Pa
    Nice work ass always Thad! but that tubing job look waaaaaay too nice for that car! That car is a SB! You were not kidding. rust and bent stuff abound!! LOL. Love the sawzall FTW on that trunk floor. How you getting the air to feed the fan? Rear seats out? Run it in reverse for winter heat!!!!
  16. #41
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    I vote for rally-style roof scoop + NACA ducts in the rear quarter windows like a stock car
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  17. #42
    DeWitt, Michigan
    Thanks Chris! Lol, it is an absolute pile of s#!t!! My thought process is to keep things as "bolt-on/bolt-off" as possible in case I want to pick up a more solid E36 or E46 chassis at some point. But I really love this one while it lasts, because of the No Fs Given-ness of it. Totally my kind of fun.
    Looks like the radiator is going to sit about 10" forward of the rear edge of the spare tire well, so it's possible that there will be plenty of airflow available just from the bottom of the car (with the Ford Taurus fan pulling through), but I am planning to probably chop a bunch of holes in the trunk lid too. I have to say I do love the "blow heat forward into the cabin" idea though. Hahaha
    Nate, your thoughts on the scoops are excellent! I did give some thought to scoops or NACA ducts in the sides of the quarter panels instead of the quarter windows since this is a 4-door. But I'm in kind of a rush to just get it running at all, so it looks like I'm just going to try to ram ahead by whatever means I can, and see if I can destroy some sets of tires with it on the 27th. We shall see.
  18. #43
    JimLev's Avatar
    Sundance Mesa, NM
    Hell ya, NASCAR all the way. Holes in the trunk, roof scoop.
    You got the LS in it, why not.
  19. #44
    Minneapolis,MN
    2003 M5, 2014 535i
    Says "hackjob" then will produce pure fabrication porn...I'm on to you man!
    Build Thread
  20. #45
    Mar 2010
    Yeah. I think that's what they call a "humble brag". What a dick. ;^)
    2003 M3CicM6 TiAg
    Former:
  21. #46
    DeWitt, Michigan
    Haha, thanks guys, I think...
    If I live to be 104, maybe I'll learn to make welds and fabricate stuff that I really like. But this hackery will do for now, I've definitely done worse!
    Tonight I mounted the radiator, and I don't think you guys will dispute me on the hackness involved in that when you see it. Lol
  22. #47
    DeWitt, Michigan
    Finished up the new MS3X and got it wired in. Since I did a lot of the wiring from scratch instead of what I have always done before, scabbing on top of the factory wiring, I put the whole shebang together with wire nuts first. After I had everything working that way, I started back through it on the passenger side and tidied it all up using proper connectors and that sweet fabric wiring harness tape Jim put me onto. I figured I should confirm the driver's side wiring was all good still before moving on, so I video'd a cold start on E85 with open headers. Lol..
  23. #48
    May 2014
    Hockinson Washington
    Two 2003 540i6 Msports
    Your build threads are pure humbling goodness and full of quiet competence.
    Also...full of fabrication porn. Lol
    I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
    The law does NOT determine "right" from "wrong". They are unrelated.
    If you put cheap parts on your car, you will soon have a cheap parts car.
  24. #49
    Mar 2012
    Lansdale, Pa
    Man that sounds good.
  25. #50
    JimLev's Avatar
    Sundance Mesa, NM
    Love it. Just punch a hole in the hood (it'll match the rest of the car) for the open header to run thru.
  1. Replies: 25
    Last Post: 06-01-2018, 01:23 PM
  2. Local E36 Turbo M3 Ride along
    By 206danebmx in forum Pacific Northwest - US
    Last Post: 04-27-2013, 01:09 AM
  3. First ride in a turbo E30 325 (TCD)
    By ///3oris in forum Forced Induction
    Last Post: 06-26-2007, 08:47 PM
  4. first ride in a turbo M3!
    By stingraysvc270 in forum Forced Induction
    Last Post: 09-08-2004, 01:25 PM
  5. Anyone wanna let me ride in their turbo e36 m3?
    By Yenny in forum Pacific Northwest - US
    Last Post: 01-27-2004, 09:54 PM
