Results 1 to 7 of 7
Thread: Transmission 4hp24 filter
    May 2015
    New Jersey
    1991 BMW 850i
    Hi guys i just bought a new filter and gasket for my car its a 91. Looks like i ordered the wrong filter from ECS. It looks like it might be for a later model. Does anyone know if they are interchangeable at all?
    https://www.dropbox.com/sh/mxtwpkzc4...1Juopsvma?dl=0
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    24341422419 is for BMW A5s560z ZF 5hp30
    https://www.realoem.com/bmw/enUS/par...419&series=E31
    for the 4HP24 you need 15 OIL STRAINER 1 24311218571 https://www.realoem.com/bmw/enUS/sho...diagId=24_0774
    not interchangeable
    May 2015
    New Jersey
    1991 BMW 850i
    Ugh. Thanks Shogun.
    Note to self: Always double check realoem part number with the parts they say are for your car.
    Jan 2005
    Japan
    tell, them, in their fitment guide is written: *The above product applications have been written by ECS Tuning. All warranties, product application, fitment, and performance are the responsibility of ECS Tuning. For additional information see the terms of use.
    But it is genreally clear that the same filter 24341422419 does not fit into all these transmissions
    BMW E31 840Ci M60 4.0L
    BMW E31 840Ci M62 4.4L
    BMW E31 850Ci M70 5.0L
    BMW E31 850Ci M73 5.4L
    BMW E32 740i M60 4.0L
    BMW E32 740iL M60 4.0L
    BMW E34 540i M60 4.0L
    BMW E38 740i M60 4.0L
    BMW E38 740i M62 4.4L
    BMW E38 740iL M60 4.0L
    BMW E38 740iL M62 4.4L
    BMW E38 750iL M73 5.4L
    BMW E39 540i M62 4.4L
    419 fits these cars:
    5er E34 Limousine
    540i (HE51/M60), 540i (HE61/M60)
    5er E34 Touring
    540i (HK31/M60), 540i (HK41/M60)
    5er E39 Limousine
    540i (DE51/M62), 540i (DE61/M62), 540i (DN51/M62), 540i (DN61/M62)
    7er E32 Limousine
    740i (GD41/M60), 740iL (GD81/M60)
    7er E38 Limousine
    740d (GE81/M67), 740i (GF51/M60), 740i (GF61/M60), 740i (GF71/M62), 740i (GF81/M62), 740i (GG81/M62), 740iL (GJ61/M60), 740iL (GH81/M62), 740iL (GJ81/M62), 750i (GG21/M73), 750i (GG01/M73N), 750iL (GK21/M73), 750iL (GJ01/M73N), 750iLP (GK91/M73N), 750iLS (GK41/M73), 750iLS (GK01/M73N), L7 (GK61/M73), L7 (GK81/M73N)
    8er E31 Coupé
    840Ci (EF71/M62), 840Ci (EF81/M62), 840i (EF51/M60), 840i (EF61/M60), 850Ci (EG41/M73)
    There was recently a similar case in Germany and after changing the filter there was a whining sound. Turned out to be the same situation. The 5HP30 filter has the suction pipe on the side, the 4HP24 has the suction pipe at the bottom, so the bottom pipe goes deeper into the pan, with the suction pipe on the side the pump also sucked air with the ATF.
    May 2015
    New Jersey
    1991 BMW 850i
    Do any of you have experience in removing the transmission lines from the radiator? I could use some advice.
    I got them loose. And i removed the heat shield next to them to give them more wiggle room. But looks like its getting hung up on around the engine oil pan. I've tried twisting them.
    I cant see a way to get them out without bending them.
    It looks like i have to pull them back toward the transmission.
    Jan 2005
    Japan
    there are some brackets holding the lines, these you have to remove first, then the trans line can be moved a bit https://www.realoem.com/bmw/enUS/sho...diagId=17_0602
    May 2015
    New Jersey
    1991 BMW 850i
    Yeah I got both brackets off. But with the way the lines are bent. its getting hung up on the oil sensor on the oil pan and the power steering pump and the steering box. I just need a bit more space. Just not sure where I should get it.
  1. FS: Transmission sump/filter
    By 4playcamaro in forum 2002 - 2008 (E65, E66)
    Last Post: 09-13-2009, 02:26 PM
  2. 1994 525i Automatic transmission service (Filter)
    By Deanx2009 in forum 1988 - 1996 (E34)
    Last Post: 06-15-2008, 05:07 AM
  3. Transmission fluid/filter change
    By Nemesis318 in forum 1999 - 2006 (E46)
    Last Post: 08-01-2006, 08:15 PM
  4. Pelican Technical Article - Auto Transmission Fluid/Filter Replacement...
    By Wayne@PelicanParts in forum 1983 - 1991 (E30)
    Last Post: 12-28-2002, 02:54 PM
  5. Pelican Parts Technical Article: Automatic Transmission Fluid / Filter Replacement...
    By Wayne@PelicanParts in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-27-2002, 02:00 AM
