Page 3 of 3 FirstFirst 123
Results 51 to 70 of 70
Thread: BMW V8 powered Rat Rod/T-Bucket.
  1. #51
    Oct 2014
    Prescott, Az
    '95 540i/6
  2. #52
    Oct 2014
    Prescott, Az
    '95 540i/6
    Getting body panels ready for paint, finished sectioning the grill for the "chopped" grill insert.
    The body, grill & headlight buckets are away for paint. Here's a hint of what's coming back. Updates soon:
  3. #53
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Nice progress.
  4. #54
    Oct 2014
    Prescott, Az
    '95 540i/6
  5. #55
    JimLev's Avatar
    Sundance Mesa, NM
    Nice, I always wondered what a '23 BMW would look like, lol. Now I know.
  6. #56
    Jul 2018
    Louisiana
    Bmw E39 528i
    Could not have said it any better, the stripes and grill are perfect. Really good job and looks mean from the lower angle shots you took.
  7. #57
    Apr 2015
    United States
    1974 estoril blue 2002
    Awesome build man. Wish I had the time, money or skills to do something of this magnitude.
    In anticipation of your next video upload.
    Sent from my SM-G960U using Tapatalk
  8. #58
    Oct 2014
    Prescott, Az
    '95 540i/6
    Reflowed the originally flux core wire welds with a TIG, added some gussets & bracing. Also moved the motor mounts (& thus drivetrain) forward 1.5" My first time TIG welding, with help from a friend. TIG > MIG.
    Once welding was done the frame was painted in a Duplicolor Graphite Wheel Paint HWP102 & HWP103 clearcoat.
    Added a number decal, flat cleared over it. Set the tractor seats aside in favor for a set of plush boat seats.
    With the newly added color I felt the stripe needed something extra:
    Mounted the universal Ez-wire 12circuit fuse block and harness, mounted the MSD ignition box and the Speeduino EFI controller.
    Using SPDT On-On toggles I'll have the fuel pump, cooling fan & intercooler pump controlled by the Speeduino while the switches are down and manually turned on with the toggles up. I'd like the light above the start button to only be on while engine isn't running, so I'm thinking of wiring it to pin 87a of the fuel pump relay so the light is on only when power is on and fuel pump is off.
    My plan to run power to the turning headlights/turn signals.
  9. #59
    Oct 2014
    Prescott, Az
    '95 540i/6
    Plugging away on projects on the car.
    Windshield:
    Hoses, plumbing, heat exchanger & nitrous lines:
    Steering:
    Exhaust:
    Also, because I'm a nerd:
  10. #60
    Washington
    BMW 525i
    Awesome build!
    2002 BMW 525i - 6.6L LS Turbo Swap
    Follow me on Instagram at @LantzFab
    Link to LantzFab.com
    Link to my Facebook page
    Link to my build page
  11. #61
    JimLev's Avatar
    Sundance Mesa, NM
    Looks good. How much juice are you going to be spraying?
  12. #62
    Oct 2014
    Prescott, Az
    '95 540i/6
    I'm aiming for 60hp first stage, 150hp 2nd stage. Not drastic, given the weight of the vehicle I figure a little will go a long ways
  13. #63
    JimLev's Avatar
    Sundance Mesa, NM
    Hope your using a progressive controller to ramp up that second stage.
    Being as light as it is it could be a pretty intense (scary) ride.
    My 1st stage is 125HP, I ramp it up for 20% to 100% in 2 sec, then the 2nd stage throws in another 50.
  14. #64
    Oct 2014
    Prescott, Az
    '95 540i/6
  15. #65
    Jul 2018
    Louisiana
    Bmw E39 528i
    I'mm liking the wheelie bar. You have everything built super clean.
  16. #66
    Mar 2019
    Milwaukee, WI
    '99 LS-swapped 323i vert
    It is... how you say? ... AWESOME!
    Diving in at the shallow end!
  17. #67
    Mar 2012
    Oklahoma
    1997 M3/4/5
    This is great! What a unique build.
    1997 E36 M3/4/5
    ASM - Slicktop
    My LS3 Build: https://www.bimmerforums.com/forum/s...9#post30117299
  18. #68
    Nov 2016
    Long Island, NY
    A few
    Very cool build and great workmanship.
  19. #69
    Oct 2014
    Prescott, Az
    '95 540i/6
    Got her fired up for the first time last weekend, still needs extensive tuning:
    https://youtu.be/bv2v7qUwN60
    https://youtu.be/M8rLEa3RDeg
  20. #70
    Dec 2004
    Charlotte, NC
    2008 BMW M5 SMGII
    Hi, I am swapping a BMW M60b30 with 550 twin turbos and e36 pistons(manifolds bolt up in downflow position with adapters, e36 pistons lower the compression) into a Porsche Boxster (many LSx builds online to reference). I first bought a chinese built engine stand and got the engine started first. It looks like your car is the engine stand. Stay patient, and attack each problem one at a time. I used a Haltech 550, and found that I needed to upgraded the crankshaft sensor from an M50. Once I did that, and I addressed gas leaks, dry sump oil leaks, a few errors in my wiring, it eventually fired up. Love your build, and the BMW m60's are great engines, if not under appreciated.
  1. Rat rod BMWs?
    By the cheat in forum BMW Rides & Events
    Last Post: 03-22-2010, 12:24 AM
  2. Interested in a V8 powered BMW but how much am I looking at?
    By Intoxicoligist in forum Engine Conversions
    Last Post: 09-02-2008, 11:16 AM
  3. evosport releases V8 Power Pulley System for the new BMW M3, S65 V8
    By Dale@Evosport in forum 2008 - 2013 M3 (E90, E92, E93)
    Last Post: 07-21-2008, 03:22 PM
  4. Question about BMW V8 power
    By PixMan in forum 1996 - 2003 (E39)
    Last Post: 08-16-2006, 10:26 AM
