Results 1 to 11 of 11
Thread: E36 M52B20 ECU Tuning
    Aug 2018
    Lithuania
    '95 E36 320i Sedan
    Is it possible to alter/tune anything with the stock ecu, or would I have to get a chip?
    Jul 2004
    Houston, TX
    36 Cylinders
    The very early MS41 ecus had non flashable memory.
    Anything after 1996 was easy to flash.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Aug 2018
    Lithuania
    '95 E36 320i Sedan
    Damn, my e36 is '95
    Jul 2004
    Houston, TX
    36 Cylinders
    It may be flashable, i am not sure of cutoff month in 1995.
    Get the part numbers (hardware, etc) of the ecu.
    -Abel
    Aug 2018
    Lithuania
    '95 E36 320i Sedan
    I went out and looked at the ECU
    5WK9 018
    DME MS41.0
    Also looked at my cars documents and it states that the date of first registration was 1995/06/01 (year/month/day)
    Aug 2018
    Lithuania
    '95 E36 320i Sedan
    I did some research and i think that the cutoff month was 1995/09 so my ECU isn't flashable, now my question is, is it possible to swap out that ecu for a slightly newer one which can be flashed? Or is there any way I can go about this because I would like to get into engine tuning.
    Jul 2004
    Houston, TX
    36 Cylinders
    Yes, you can buy the newer flashable ecu, sync EWS (very easy), and tune that. It plugs right in.
    I just don't know what kind of power you can make from just tuning that small engine. It's almost not worth it, unless you're aiming for forced induction.
    -Abel
    Feb 2016
    France, Lyon
    323i e36 swap M52B28
    If you have M52, normally you should have MS41, it's easy to tune with partial .bin (with INPA compatible usb/OBD cable you can Flash / write in lot of easy way). I have somes files & software definition to share if you need, just message me.
    Jan 2019
    Connecticut
    E92, E46, E36
    Just curious, anyone have any experience with the miller war chip?
    Aug 2018
    Lithuania
    '95 E36 320i Sedan
    How can i contact you?
    Jul 2021
    Southern IN
    325i
    You don't say who you want to contact lol but click on their name and click private message....
  1. E36 FS: E36 OBD 2 ECU tuned by JimComforti Shark Injector w/ EWS module and key chip
    By omarmarji in forum Engines, Performance Parts & Software
    Last Post: 03-18-2013, 11:39 AM
  2. E36 WTB USED 1995 E36 M3 OBD 1 ECU tuning chip (DME 413)
    By jostian in forum BMW Parts Wanted
    Last Post: 07-11-2010, 02:34 PM
  3. 1999 E36 M3 ECU with Active Autowerke tune
    By pilot650 in forum Engines, Performance Parts & Software
    Last Post: 01-27-2009, 02:39 PM
  4. E36 M3 OBD-II S/C ECU tune ~8psi
    By Krank in forum Race Cars & Track Parts
    Last Post: 04-07-2008, 09:04 PM
  5. Obd2 E36 M3 Ecu F/s & Vortech Sc Tuning
    By dinans3m3 in forum BMW Parts For Sale
    Last Post: 11-01-2006, 08:06 PM
