Results 1 to 3 of 3
Thread: Quick NCS Dummy question - how to know which ECU to select?
    Aug 2018
    Sheffield, UK
    2004 E60
    Hey there
    Most of the coding that I've done on my 2004 E60 has been directly using NCS Expert, but I've had very little luck doing so and a whole lot of error, so I'm coming back to it renewed and looking into NCS Dummy to do so. I think I'm pretty confident on how to use NCSD to do what I want, except for one thing: when selecting a chassis and ECU for NCS Dummy to read the trace file, there are always several versions of the ECUs, usually affixed with something like a C01, C02, etc. When reading data from the trace file, how am I supposed to know which version of the ECU I need to use? Is there a guide for this anywhere?
    Would really appreciate some help with this. Thanks!
    Jul 2004
    Houston, TX
    36 Cylinders
    https://www.bimmerforums.com/forum/s...-of-NCS-Expert this thread was right under yours, revtor put a very good instruction writeup there.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Nov 2007
    Belgium
    Made in Germany
    Carefully read chapter 6.1 of the NCS Dummy user manual. It explains where and when NCS Expert displays the information you need for NCS Dummy, just as well as how to create proper trace files with NCS Expert.
    Nevertheless, if you have a trace file of which you do not know the module you can make NCS Dummy detect the most likely candidate. See chapter 3.6 for more information.
  1. quick question, need to know stat!
    By stuart20 in forum 1983 - 1991 (E30)
    Last Post: 06-16-2007, 01:05 AM
  2. quick clutch/flywheels question....
    By 232is PoWeR in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-24-2001, 12:00 PM
  3. audio questions (vague, I know)
    By Guillermo in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-06-2001, 04:44 PM
  4. Quick wheel offset question... thks
    By TC3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 05-21-2001, 12:02 AM
  5. Quick oil change question..
    By Anfanger in forum 1991 - 1999 (E36)
    Last Post: 03-19-2001, 08:21 PM
