Intro:
This thread is going to be used as a progress journal of sorts. A way for me to document the journey of (hopefully) restoring this abused e46 to the best of my abilities. If not to Show fame then at least to Go fame, as right now it is parked with a flat tire and 6 engine codes (until I read and deleted them). Hopefully it makes for a good read, as I've always found forum threads to be beneficial when it comes to tracking your work or simply asking for advice along the way.
The Backstory:
I'd always had my eye on my father-in-laws BMW anytime we'd go visit. Mainly because I saw the potential in the car from the first time I'd laid eyes upon it. He is a construction worker and used it as his work car, so trust me it's been through some hell. From time to time I'd order parts for him or go by to help him with small jobs (soldering tail lights, recommending parts or part sources) but it never went further than that. The months went by, my fiance and I moved to NC for work back in May of 2017, and life moved on. Well, about 2 months ago we moved back to CA and reunited with the family. He got an actual work truck, and about a week ago my father-in-law (Eric) decided to hand the car over to me free of charge. My first thought wasn't "what a nice guy", or "wow he must really like me". It was more along the lines of..."ok what the hell is wrong with it?". My wife's first thought was "wow he really likes him!", but that quickly change to..."wait what the hell why didn't he offer it to me?!?" Long story short, we aired up the flat tire and drove it and all of it's engine codes to our place as I was anxious to start figuring out why he donated this unnamed e46 to me.
The Project:
A 2002 E46 330i sporting an automatic transmission with 188K on the engine and chassis. It's shell is painted titan silber metallic paint (most of it anyways) and it's guts are standardleder/grau.
I have yet to physically drive it, but from what I can tell it leaks coolant (or water in Eric's case ), it leaks power steering fluid, and it won't pass emissions here in CA. First thing I did after parking it was run codes and get to doing research on them.
Codes:
P0313
P0455
P1083/P1085
P0171/P0174
After that I started looking online, trying to establish a starting point as well crunching numbers on how much it will cost to get this thing to pass rego and back on the road. Aesthetics are definitely on the back burner (though I said that about my MK3 Jetta and I managed to sprinkle in some parts every now and then, but only out of necessity ).
The Game Plan:
My game plan is simple. Research and repair as much of this stuff on my own starting with the coolant and evap systems. I've been watching 50'skid videos (ton of help) and will be reaching out for advice, but here are the plans so far (in a somewhat specific order). If you do have any advice or recommended brand names to these parts, please drop those in this thread as I'll need all the guidance I can get.
Emissions:
P0313
Buy fuel injector cleaner and change fuel filter
P0455
Replace gas cap (if needed) and check all evap hoses
P0171/P0174
Check CCV and hoses
Clean MAF
Replace Air Filter
Check PCV lines
Check PCV valve
Check lower intake boot
Check upper intake boot
Replace O2 sensors (if needed)
Cooling System:
Replace expansion tank
Replace upper/lower rad hoses
Replace o ring seal coolant sensor
Replace thermostat/t stat housing
Replace water pump
Fill with actual coolant once leaks are gone
Power steering:
Check power steering pump hose for leaks
Other:
Check cabin air filter
Check DISA valve
Check/Repair VANOS
Check oil filter gasket housing
Replace driver side door lock mechanism
Replace/patch passenger side tire
Replace kidney grills
Fix power locks (non-op)
Replace rear passenger/driver window regulators
Replace front bumper
Replace windscreen
Replace Raiders license plate frame
Check ATF fluid
Summary:
This is going to be a slow and steady operation, but I do plan on posting any and all progress here. I'm new to the BMW community, and am confident that I can get this thing back on the road again. Thanks, and peace for now!
Tip: don't replace your O2 sensors just yet. Inspect the intake for vacuum leaks (remember the brake booster), clean the MAF as you already suggested and preventively replace the PCV. That will probably fix your lean issue already. The O2 sensors rarely go bad so the issue is more likely somewhere else. If all else fails and they need replacement: always get genuine BMW sensors, as aftermarket sensors regularly cause problems.
You have a sentimental value connected for this BMW car, I appreciate that. A grand effort and much funding can resurrect this BMW car..for sure.
The 330 is a sweet ride when it is working correctly - so keep your eye on the prize.
Meh - no sentimental value attached really. Just couldn’t picture seeing this thing scrapped considering the (potentially) easy fixes to get her up and running. Plus I’ve always admired bimmers, so I couldn’t pass up the opportunity to learn about them by wrenching on one myself. Diamond in the rough.
A somewhat grand effort yes, but most of the codes are related to standard maintenance items anyways. Things I would have rebuilt regardless given the miles on it. That’s assuming I don’t run into any major issues along the way of course. The “much funding” will come with modifications and buying pay to play parts and goodies I’ll probably want down the road lol. Now if I was going to the stealership for parts/labor than yes...one would get raped no lube going that route. But hey the car was free and doesn’t show any signs of major irreparable damage. Guess only time will tell...
Similarly I have acquired a 2004 325i for next to nothing. A product of a front end collision. Car has 200k miles on it. Hoping to get some help and direction on the forum on how or what I should do to get this thing up and running. Good luck brother. Hopefully we can keep in touch as we're both embarking on very similar journeys.
-James
Charleston, SC
(443) 557-8099
Good Luck 330i project.
I just purchased a 04 325ci and after 20 miles a check engine code popped up. I bought it from a BMW dealer so will see what goes. I have ordered a code reader, Foxwell that will arrive some day from China and a service manual that should be here today. I have never owned a BMW but have been in love with them forever. I started with wanting an older Z3 but never pulled the trigger on one. i decided on the 3 three series about three months ago and was surprised how many are out there. Thanks to this thread I will change the PCV and try and find the MAF and clean it? I disconnected the positive battery last night for an hour and when I reconnected it the light was still on. Maybe I should have disconnected the positive and negative. Anyway I am diving into a 14 yr old convertible sports car and will follow your journey for ideas.
Jeff from Houston
Lots will help here..a few may not!
I just acquired for almost free a new to me 330 e46 also. Sounds like we can swap stories, I started a thread on mine also.
First thing I learned is almost all rubber goes bad, replace vacuum lines, intake, valve cover gaskets.
Basically you have ALL of the general maintenance due. Easiest solution go to ecstuning and buy their refresh kits: coolant system, get metal pulleys etc.
Then refresh all fluids.
Check all rubber bushings and replace as needed.
Change oil.
Replace any worn out parts.
Go drive and have fun.
Welcome to Bmw driving!
_________
1980 320i - Kashmir Metallic - Sold in 1993
1985 535i - Cosmosblau Metallic - Sold in 1995
1985 535i - 1985-06 - Delphin Metallic - Sold in 2016
1983 320i - 1982-09 - Kashmir Metallic - Currently own!
2004 ZHP - 2003-08 - Titanium Metallic - Currently own!
2000 M5 - 2000-02 Titanium Silver - Currently own!
