Results 1 to 3 of 3
Thread: Throttle issue
    Mar 2017
    Palmyra, VA
    1994 325is, 2001 325ci
    Throttle issue
    Hey guys, strange issue with the car(01 325ci). When cruising at steady speed, the car will fall on it’s face for a second or two then come right back, 10 seconds later it will do it again. Isn’t all the time and have not been able to pin point a certain throttle position that does it. What I noticed when watching the data stream was that the throttle pedal angle and throttle angle would go to zero, the pedal signals 1&2 and the throttle signal 1&2 voltage readings didn’t change. Car has no software modifications(shark tuner, pedalbox, etc). Only things on it are a cold air intake and Remus cat back, neither of which are new to it. The only fault code is inlet cam sensor signal which has been there for a while(sensor was replaced, vanos rebuilt 6 months ago), there’s also 2 accelerator brake pedal plausibility codes...from heel toe downshifting. I have a creator c110+ tool and have reset adaptations but haven’t driven the car yet but honestly don’t think that will change anything with this issue. Pedal position pot failing maybe? I’m still new to this drive by wire system so any input is appreciated.
    Apr 2015
    Netherlands
    2000 E46 328i
    Clear the codes, drive until the fault occurs and then check again.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The problems are that the throttle and pedal data streams are both going to zero. You likely have a wiring problem. The DME provides the power to these subsystems.
  1. throttle issue
    By SilverBeam in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 07-28-2007, 04:35 AM
  2. 1990 BMW 735i i think 3.5L.. throttle issue? please help
    By sinanovicha in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-19-2007, 04:01 PM
  3. Hesitation and part throttle issue
    By Jim M3 in forum Forced Induction
    Last Post: 04-30-2007, 06:04 PM
  4. RPM / Throttle issue
    By sarge in forum 1991 - 1999 (E36)
    Last Post: 02-19-2007, 04:41 PM
  5. HELP! 318 / M42 / DME 1.7 surging throttle issue
    By DerekVa in forum 1991 - 1999 (E36)
    Last Post: 05-24-2006, 02:27 AM
