2003 Z4 3.0i
Thinking of getting the MAOZUA Latest V7.7 Creator C310+ Diagnositic tool
Is it any good or should I be looking at another tool?
For an affordable standalone unit, Foxwell nt510(nt520 Updated version) is the preferred unit, along with required cables.
It can scan for BMW codes, among other things, as it can communicate with all BMW modules.
HERE:http://www.foxwelltool.com/wholesale...d-version.html
You think so?
I don't think soo...
Compare their features side by side,you'll see!
I would like to but it gives me brain ache as I dont fully understand what the info/data is - Im old school I can fix my Triumph Spitfire, Volvo 240 or MGB Roadster by the side of the road becuse I know whats wrong with it by listening to it with no gadgets!
So what does the Foxtel have that the Creator dosnt - I know that Airbag re-setting is an issue which I think the Foxtel has and thought the Creator had!?
Any help, however brief .. would be appreciated.
Great signature joke!
Foxwell NT520 Features and Benefits:
Compatible with both OBDI and OBDII vehicles
Work on the latest 2016/2017 models
Get access to power train, chassis and body systems
Quick test function to test most vehicle systems
Read and clear diagnostic trouble codes and reset MIL of all systems
Request and record live sensor data
Merge and view 2 parameter graphs simultaneously
Display freeze frame data
Retrieve ECU information
Support Oil service reset functions on selected make
Support Electronic Park Brake (EPB) features on selected make
Upgradable to cover other car makes
Multi-language menus and code definitions for an international market place
TF memory card for data backup and software update
As easy as 1-2-3 with large TFT color screen and menu-driven operations.
Ergonomic design and ruggedly built for both shop and road tests.
It is free for lifetime after your purchase
Optimize the upgrade method to allow users to update the scanner via USB connection instead of SD card
NT520 cannot only read your codes, but it can also actuate components, run system tests, program control modules. Reading the trouble codes from your vehicle is easy, but without live data, bi-directional controls and other special functions, you may not have enough information to get the problem fixed right. It allows you to use the scan tool temporarily activate or control a system or component. With NT510, the check of electronic components such as switches, sensors, relay and actuators is made a simple task, saving your time and labor costs. It gives you the ability to flash a control unit with ne program data. Provided that a module can be re-coded, NT510 allows for the coding and programming of a replacement control module or changing previously stored incorrect coding as expensive factory tools do.
I have the Creator, for the money, it can't be beat. CLEARED ABS and DSC lights for me after I cleaned wheel speed sensors, and said I have a fault with a convertible top module.
GREAT PRICE!
Nice way to get it.
