Results 1 to 10 of 10
Thread: 2004 325i questions
    Jun 2018
    Camp Hill, Pennsylvania
    2004 BMW 325i
    2004 325i questions
    Just purchased this 325i with only 95,000 miles and the body is mint as is the interior !
    Have 2 problems
    1 check engine light is saying problem with cylinder 3 so I changed out the plug and coil the light went off for a week and its now back on. When I start the engine it has a rough idle and after 2 minutes if I shut it off and restart it then it runs smooth. So it doesn't make sense if it was the injector why the restart would correct it.
    2nd problem just started after having the car for over a month when I take it out on the highway and go over 65 mph the car rumbles in the front when on the gas but if I let off it smooths out ! Could this be transmission ?
    Hope someone has experienced this and pass along the knowledge
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Does the car have maintenance records? Was the fuel pump ever replaced? Fuel pumps can “soft fail.” That means the pump can’t provide the required volume of gas at 50 psi. Also, what brands of gas did the previous owner put in the car? El cheapo gas can gum up injectors.
    The noise could be caused by any number of things. Btw, is the transmission a manual or an automatic?
    Jun 2018
    2004 BMW 325i
    Quote Originally Posted by MarcoZandrini View Post
    Car has no records. Thank you will have the fuel pump checked Still cant figure out the miss fire going away after restarting
    its a automatic
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Check the fuel pressure at the fuel rail. Item #2 in the link is the cap for the test port. Pressure has to be at least 50psi at all engine speeds.
    https://www.realoem.com/bmw/enUS/sho...diagId=13_0900
    Also, check the boot that connects the coil to the spark plug. Check the connector to the cylinder #3 coil.
    Jun 2018
    2004 BMW 325i
    The connector is tight I looked all over the net for a replacement pigtail couldn't find any. Do you know of any ?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Go to www.realoem.com and enter the last 7 characters of the car’s VIN. Hit enter and bookmark the page. Scroll down to engine electrical to get the part #. I buy parts from FCPEuro.
    Jun 2018
    2004 BMW 325i
    Thank you ! Very cool site ! But they have no pigtails just the entire harness $ 170.00
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Each cylinder coil has its own boot. Check realoem under engine electrical. What tool are you using to scan for codes? What’s the fuel pressure?
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved from BMW General Discussion sub-forum.
    88M3 AW 43k miles Project FS
    Jun 2018
    2004 BMW 325i
    Well here's a update ! All problems fixed ! Yes the Fuel Filter was clogged ! Fixed the rumble after going fast.
    I was getting air in the coolant I have a small hole in the head gasket. So used Bar's Leak repair fixed the air getting in the coolant system and cylinder 3 no more error code !
  1. 2004 325i w/Sport pkg - tire question
    By sammk in forum 1999 - 2006 (E46)
    Last Post: 12-30-2007, 08:22 AM
  2. 2004 325I Question
    By jwpaner in forum 1999 - 2006 (E46)
    Last Post: 10-07-2007, 09:33 PM
  3. 2004 325i - new owner questions
    By alpinex in forum 1999 - 2006 (E46)
    Last Post: 09-06-2007, 08:53 PM
  4. Questions about the 2004 325i
    By konabiker47 in forum 1999 - 2006 (E46)
    Last Post: 01-29-2006, 01:58 PM
  5. Questions about the 2004 325i
    Last Post: 01-29-2006, 12:48 PM
