Page 5 of 8 FirstFirst 12345678 LastLast
Results 101 to 125 of 177
Thread: E46 330i Turbo - Street / Drag Race Project
  1. #101
    Sep 2018
    Canada
    2015 Audi Q5
    Quote Originally Posted by TheJuggernaut View Post
    Are the pics working for everyone else?
    No the pics are not showing up, seems to be only this page.
  2. #102
    A house
    '86 325e, '14 VW EPA
    Quote Originally Posted by AlexQuattr0 View Post
    Cool, I thought it was just me and I somehow got banned by photofuckit
  3. #103
    Vancouver, BC Ca
    1993 325is
    Ya. Pics that were there yesterday when I posted my comment are gone. There are no broken links. Nothing. Like a pic was never posted (but they obviously were).
  4. #104
    Jul 2005
    PEI, Canada
    2001 330i
    I'm having problems uploading new images as well.
    I'll dig into it...
  5. #105
    Jul 2005
    PEI, Canada
    2001 330i
    Test
  6. #106
    poconos pa
    e36 m3, turbo e36
    Picture is working for me
    -sold...replaced by turbo e36
  7. #107
    Sep 2018
    Canada
    2015 Audi Q5
    I see 2 pics.
  8. #108
    Vancouver, BC Ca
    1993 325is
    Yup. Nice rad!
  9. #109
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Sweet radiator! What are all the ports for? Is it a custom unit or off the shelf?
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  10. #110
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by 3literheater View Post
    It's a custom unit I had Bimmerworld source for me.
    On the right side of the radiator, (under pressure cap) there is an 11 plate oil/water heat exchanger integrated into the end tank.
    The -12 AN bungs on the bottom of both end tanks are for an auxiliary cooling circuit I have planned. (It will have it's own pump)
    The fans flow roughly 1600 CFM each, and draw approximately 16 amps each.
    Core thickness = 2.56"
    Height = 24.5" (not including rad cap)
    Width = 27.5"
  11. #111
    Jul 2005
    PEI, Canada
    2001 330i
    I'm going backwards a bit here....but while we were assembling the head, we found that a couple of valve locks had cracks on them.
    I don't know for certain what caused the cracks, but I have a guess. One of the methods I've used to pull the valve locks out is to hit the top of the retainer with a socket and a hammer. The valve stays in place, the spring compresses, and the locks fall out of the slot. I think that while doing this, a lock might have turned sideways and then been compressed by the returning valve retainer and spring causing it to fail. I've disassembled this head twice now, so the possibility seems higher. I think in the future I will use a valve spring compressor (Same as we use to assemble) and take the valve locks out carefully.
    Even though there were only 2 locks found damaged, I decided to replace them all just in case. So a new set of 48 locks is on the way from Supertech.
    Considering I thought the head was "Good" when I ran it before, I've done a surprising amount of work on it:
    - New valve guides
    - New valve seals
    - Valve seats re-cut
    - New valve springs and retainers
    - New valve locks
    So this leads me to question my ultimate power goals, because my tolerance for wrecking/breaking stuff has decreased significantly over the past couple of years. Where I used to consider an engine rebuild to be like washing ones clothes, I now see it like having to do a major house renovation. The thought of toasting this engine build, after what might amount to a handful of hours of use, is highly disturbing. The M54 engine in general is still widely unproven above 800hp, so I'm having second thoughts on my 1100hp goals.
    Championship level "Dumb ass":
    I put the BMW outside with a cover over it while I was doing some work on my wife's car on the lift. Because I ran into some issues, I left BMW outside overnight. Then I woke up in the morning to find that we had gotten significant snow, and that my car cover was blown half way across the back yard.
    The car was full of water/snow.
    Good thing the floor is getting cut out....
  12. #112
    Apr 2006
    Minnesota eh?
    86 325es
    Build two motors. If you know that you have a backup motor sitting on a stand at home you'll be much less hesitant to blow it up.
  13. #113
    Jul 2005
    PEI, Canada
    2001 330i
    And there lies the problem.
    I started talking to Mazworks last August, and Mark had a ton of very constructive ideas based on practical experience. This discussion made my current engine build obsolete, and many of my ideas for future projects were put in doubt. Mark didn't think running 2 cooling systems, (One for the head, and one for the block) was a useful feature. More importantly, he felt that the welding to close the deck of the cylinder head would have caused softening of the cylinder head core in areas where we actually want it to be stronger. In other words, I might have taken a step backwards!
    So if I was to start from scratch with stock M54 cores, and had Mazworks do their magic with sleeves, billet main caps, big studs, head porting, and valve train, I'm probably looking 2 X $30k engine builds. I just don't have that budget right now...
  14. #114
    Jul 2005
    PEI, Canada
    2001 330i
    I guess the other thing I could do is simply build another bottom end with exactly the same hardware as my current engine build....but I think that would bug me. I'd know that it could be better....
  15. #115
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Sucks about the car over, a holepunch and zipties on all 4 wheels helps, but hindsight is always 20/20
  16. #116
    Apr 2006
    Minnesota eh?
    86 325es
    Perfection is the enemy of progress. Just get another block, sleeve it, put timeserts in it, and a stock head, upgraded valve springs, off the shelf rods and pistons. 1100 hp is not that much, don't go nuts over it.
  17. #117
    Nov 2008
    New York, NY
    2001 BMW M5, 2005 BMW M3
    What about moving to the S54 platform? Wouldn't be necessary to use sleeves, valvetrains for 9k rpm available, etc.
    --Peter
  18. #118
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by PEI330Ci View Post
    You all know that spending the money to have a fully built backup motor waiting in the wings is a sure fire way of ensuring the primary motor will NEVER blow!! It's like spending loot on rain tires and wheels and then it never rains at the track!
  19. #119
    Nov 2008
    New York, NY
    Quote Originally Posted by jakermac View Post
    Absolutely true story. I have used my rains once in what, three years?
    --Peter
  20. #120
    Sep 2018
    Canada
    2015 Audi Q5
    Is this for a drag application only? or road racing (TARGA)?
    I remember when you first started talking about this a few years ago (I brought it up a few posts back) but I haven't seen you post any more than 2 pics of the cylinder head from a distance.
    Did you ever post about this in depth? It would be cool if you'd elaborate more on the reasons why you thought that having a cooler cylinder head would be important and also post some closeup pics. You mentioned that a special jig needed to be built to hold down the head, do you have any pics of that?
  21. #121
    Jul 2005
    PEI, Canada
    2001 330i
    Ready:
    Set:
    Gone:
    I've got to find a better way to do this:
  22. #122
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by E36 HateR View Post
    I can count the number of times I've used that cover on one hand since I bought it in 2010.
    I have another engine, but I'm debating what to do with it in the long term. Right now, it's the mock-up piece for fabrication while we rebuild my other engine.
    Quote Originally Posted by herrubermensch View Post
    --Peter
    Peter,
    People keep telling me this. :P
    What's quite interesting is the number of block failures I've been exposed to with the S54, where the cylinder wall splits under pressure. So I think to be sure, I'd want to sleeve the S54....which would cost the same as doing an M54 block. The cylinder head is better on the S54, but it's a heavier engine as well. If Mert ever fires up the Billet S54 block he had Mazworx build him, we might have a case for conversion....
    Or taking tools to the track!
    It's a mix of street car, drag car, and track day car.
    I'll comment on the "cool head" later.
  23. #123
    Sep 2002
    USA
    BMWs
    Oh man... this makes me want to do something w/ my car again... but at the same time makes me want to not bother... lol.
    #dadlife now
    Good to see you're still at it!
  24. #124
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by 5mall5nail5 View Post
    #dadlife now
    #dadlife
  25. #125
    Vancouver, BC Ca
    1993 325is
    So. These pics are what, a couple days apart?
  1. twin turbo V12 drag racing
    By tread72 in forum 8 Series (E31)
    Last Post: 03-28-2008, 03:02 AM
  2. Evosport E46 M3 Turbo BMWCCA Club Race Report at Willow Springs
    By jdholder in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-19-2007, 02:42 AM
  3. WTB E36 or E46 M3 engine for road race project
    By futureroadracer in forum BMW Parts Wanted
    Last Post: 11-30-2006, 08:22 PM
  4. WTB E36 or E46 M3 engine for road race project
    By futureroadracer in forum BMW Parts For Sale
    Last Post: 11-27-2006, 10:44 PM
  5. Sydney: WSID Off Street drag racing Wednesday nights.
    By MrBlonde in forum Australia / New Zealand
    Last Post: 02-14-2006, 06:19 AM
