Page 3 of 8 FirstFirst 12345678 LastLast
Results 51 to 75 of 177
Thread: E46 330i Turbo - Street / Drag Race Project
  1. #51
    Jul 2005
    PEI, Canada
    2001 330i
    The Quick Time bell housing was modified to fit BMW starters. (It now fits M50-M54 starter depths of up to 57mm)
    Then I mounted up everything to start the mock-up in the chassis:
    And found that I need to modify the dust shield for the dry sump oil pan:
    Slinging it:
  2. #52
    Jul 2005
    PEI, Canada
    2001 330i
    Obviously, the side mounted shifter was going to need some clearancing to happen:
    So I did.....but then found that the bell housing hit the trans tunnel:
    I ended up cutting out part of that area of the tunnel, and then using the BFH to get the remaining clearance needed:
  3. #53
    Jul 2005
    PEI, Canada
    2001 330i
    Adding a few items to the interior to check the layout:
    The shift mechanism sits 7" left of centre, and would hit the seat if I had it mounted where I wanted it:
    With the transmission in 2nd gear, the shift lever nearly hits the steering wheel in the position that I want it in:
    It really doesn't matter though.
    Today I'm looking at moving the engine back through the firewall a significant amount to give more space in the engine compartment for "things".
    Regardless of where the engine is going to sit, I'm going to make new engine mounts out of steel. With the kind of torque I will be making, with a dog box transmission, and slicks, the engine mounts are going to take a beating...
  4. #54
    Mar 2011
    Canadian in California
    Makes whoosh noises
    1000+RWHP, Lab22 Built Turbo S54 - BMW Half Mile Record Holder
  5. #55
    Norristown PA
    mostly bmw
    Oh my goodness. These pictures actually make me feel giddy, like I did when I first got into this whole turbo BMW thing. Great job here sir.
    95 turbo 330ti. 01 maxpsi m3 e85. 01 m5. 01 m coupe. 03 AIM 996t e85. 06 x3 w/Meyers plow and winter daily. Prussian Motors is hiring!! prussianmotors.com/jobs
    Current e39t LS Turbo swap: https://www.bimmerforums.com/forum/s...LS-e39-Touring
  6. #56
    Vancouver, BC Ca
    1993 325is
    Why couldn't all that extra trans/bellhousing have been on the passenger side!!! Oh, and your steering wheel is to big! ;p
  7. #57
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by jakermac View Post
    The bell housing is equally large on both sides.....and if it was shifted all to the passenger side, I've have an exhaust routing issue. In fact....I already have one. The 4" flange on the turbo sits right next to the bell housing....I'm going to have to do some more "clearancing" to make things fit.
    New engine mounts are done....part of the valve cover officially resides under the front window now.
  8. #58
    Jul 2005
    PEI, Canada
    2001 330i
  9. #59
    Jul 2005
    PEI, Canada
    2001 330i
    Getting serious about cutting:
    25 pack of wheels, and a new grinder. (I have 2 grinders, but I'm always having to switch the wheels out, so I figured it was time....)
  10. #60
    Jul 2005
    PEI, Canada
    2001 330i
    Crickets:
    Boom!
  11. #61
    Mar 2011
    Makes whoosh noises
    What's the plan with the exhaust off the turbo?
    Great progress btw keep it coming!
  12. #62
    Apr 2006
    Minnesota eh?
    86 325es
    keep cutting until you can bolt the trans yoke to the diff yoke.
  13. #63
    Jul 2005
    PEI, Canada
    2001 330i
    Like a rear engine dragster....I've been tempted. :P
  14. #64
    A house
    '86 325e, '14 VW EPA
    Speaking of yokes, consider getting a quick release. I don't know how deep the diff sits in the E46 carrier frame but in the E30 it's too deep to be able to collapse the slip joint enough to get the DS out of the diff. I have a very cool Mark Williams piece, makes DS removal one of the easiest jobs on the car as opposed to the pain in the ass it usually is on BMWs.
  15. #65
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by TheJuggernaut View Post
    Don't you run the yoke out 3/4" from the seal?
  16. #66
    A house
    Quote Originally Posted by PEI330Ci View Post
    1". Not enough to clear an E30 subframe.
    edit: nmind, googled an E46 subframe/diff mounting pic, not a concern for you.
  17. #67
    Chicago
    '99 M3
    I used to run a bottom mount setup from Cartech and it was crazy. Almost immediate reaction from a turbo. I kinda wish I would have stayed with that setup at times. Have fun with your project!
    TEC-3R, T4 GT40, WISECO, EAGLE, SUPERTECH, O-RING'D "FRANKENSTEIN" STROKER.
  18. #68
    Vancouver, BC Ca
    1993 325is
    I have a very cool Mark Williams piece.
    Link? 1310 joint compatible?
  19. #69
    Apr 2006
    Minnesota eh?
    86 325es
    Get a quick release front yoke anyway because your going to have to have a driveshaft loop in the tunnel too and it’s a million times easier to just take off the front and leave the shaft in the car vs taking off the rear and fishing it though the loop and onto the output spline. Been there done that. Mark Williams are the best. I have a Inland Empire one in there now, they said it was rated for 2000 hp.
  20. #70
    A house
    Mine is a 1350 but they probably have a 1310 version. Full list:
    https://www.markwilliams.com/transmission-yokes.html
  21. #71
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Damn that turbo exhaust is close to the bell housing!!
    I am interested to see how you close the trans tunnel back up.
    Great work as always! Keep it up.
    Side note: Quick Time called me and had me send my bell housing back for modification.
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  22. #72
    Jul 2005
    PEI, Canada
    2001 330i
    Quote Originally Posted by 3literheater View Post
    Weeks ago, I contacted Quick Time directly through their website, and received an automated confirmation that they received my message. To date, I have heard nothing back from anyone at Quick Time. (Or Holley)
    If they have indeed received my feedback, I hope that others don't have to go through what I have with their product. I got billed $250 for a professional (accredited) welder to fix it, so it will be considered properly welded by the NHRA inspector.
  23. #73
    Jul 2005
    PEI, Canada
    2001 330i
    To move the engine, I needed to fabricate new engine mount arms. I had 1/4" thick plates cut for me, then drilled them out to be mounted to the side of the block. Then I tried to position the engine and transmission into the car to built the mounts:
    That failed.
    I had a very hard time getting the engine rotated to be on a 30 degree angle, while using the engine lift and conventional pickup points. The windshield was in the way, and the COG of the engine was just off.
    The Juggernaut (Dmitry) suggested I do it out of the car with the engine on a stand, and use the front crossmember to do the mock up. This worked out really well.
    Setting the angle:
    I made a platform/jig to hold the front cross-member with the OEM engine mounts in place:
    I then marked the bottom of the oil pan to see how far back I was able to move the engine:
    With the subframe locked in place, I then started tacking together the new engine mount arms:
    The finished result:
  24. #74
    Jul 2005
    PEI, Canada
    2001 330i
    Doing compound cuts on pipe bends for the new WG mounting:
    And...thanks to all the EGT bungs on the bottom of the SS manifold, I can't run the 2.5" charge pipe where I was looking at before. (Just under the manifold) So I mocked up the 4" turbo inlet pipe, and started looking at running the charge pipe over the cross member, but starting with the compressor outlet pointed down:
    I think I've got it figured out....
  25. #75
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    You lost a bit of your car...
    I saw a cool S14 240SX that had the engine moved back really far to where the end of the windshield was sitting over roughly cylinder 2 or so. To work on the engine they had the windshield flip up and a dzus'd cover over the engine and one for the trans that was quick and easy to remove. It actually seemed super easy to work on the engine just sitting inside the car with the covers removed.
    Thought about pushing things back EVEN MORE?
  1. twin turbo V12 drag racing
    By tread72 in forum 8 Series (E31)
    Last Post: 03-28-2008, 03:02 AM
  2. Evosport E46 M3 Turbo BMWCCA Club Race Report at Willow Springs
    By jdholder in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-19-2007, 02:42 AM
  3. WTB E36 or E46 M3 engine for road race project
    By futureroadracer in forum BMW Parts Wanted
    Last Post: 11-30-2006, 08:22 PM
  4. WTB E36 or E46 M3 engine for road race project
    By futureroadracer in forum BMW Parts For Sale
    Last Post: 11-27-2006, 10:44 PM
  5. Sydney: WSID Off Street drag racing Wednesday nights.
    By MrBlonde in forum Australia / New Zealand
    Last Post: 02-14-2006, 06:19 AM
