Results 1 to 7 of 7
Thread: M54 burning oil at idle
    Aug 2018
    Pdx
    01 325it
    i recently purchased an E46 325it, after some research i had fount he the reason for burning oil is most likely the CCV system. i have replaced the CCV system with factory BMW parts, also the valve cover gasket and the oil pan gasket. I have checked all of my vacuum lines and i can not figure out if it is a vacuum leak or just bad rings. i assume that i it was bad rings than i would burn oil a higher RPMs as well as at idle. not sure where else to look. maybe dipstick o-ring.
    It seemd thebe worse when i slow to a stop on a down hill.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The M54B25 engine (this is BMW’s designation) isn’t known to burn oil. The 3 liter version (M54B30) dies burn oil. Your last sentence seems to be the key, if I read it correctly. That is, the engine burns oil when you’re engine braking as the car goes down hill. That’s a good indication that the valve seals are shot. They can be replaced without removing the head. If you decide to replace the seals ensure you buy seals made by the supplier to BMW.
    Now, if I misinterpreted the last sentence then the cause could be the piston rings. Go to E46Fanatics and search for GM Top End Cleaner soak. Basically, you remove the spark plugs and pour a couple of once of the GM fluid into each cylinder and allow it to soak for 24 hours.
    Aug 2018
    Pdx
    01 325it
    I guess the next task would be to do a leakdown test and see where it's leaking.
    Jul 2004
    Houston, TX
    36 Cylinders
    I think he meant valve stem seals.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    What makes you believe its just burning oil at idle?
    Aug 2018
    Pdx
    01 325it
    because i only get smoke at start up and when i slow to a stop. i believe it builds up in the exhaust and i get a cocentrated cloud when i then take off. like i said it is the worst on down hill stops and on uphill it seems to be a little less so.
    Apr 2015
    Netherlands
    2000 E46 328i
    +1 on the valve stem seals.
  1. M54's that burn oil, it probably isn't leaking out...
    By Julian in forum 1999 - 2006 (E46)
    Last Post: 04-12-2016, 11:27 PM
  2. Burning oil,irregular idleing and losing power
    By rohan9248 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 12-03-2014, 01:22 PM
  3. Burning oil, rough idle, white smoke during start up
    By boostinm3 in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 03-19-2014, 09:03 AM
  4. Arrrgh! M54 burning sooo much oil!
    By Silberwald in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-18-2011, 10:24 AM
  5. Burning oil and idling rough...
    By camaroguy in forum 1988 - 1996 (E34)
    Last Post: 05-27-2009, 09:36 PM
