Results 1 to 8 of 8
Thread: Idle control module - help
    Jul 2018
    Atlanta
    1992 e30 318i vert
    Does anyone have a pic of the E30 M42 idle control module in its correct location next to the ECU? Just to make sure, I am not asking about the ICV which is in the engine bay. I pulled the glove box out and the ECU but I can't find anything that looks like what I think the ICM looks like. Is it around the AC blower/behind the radio? Maybe the PO eliminated it previously. Thanks.
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    google for pics? I know I do not have one
    No e30s again.
    Jul 2018
    Atlanta
    1992 e30 318i vert
    All the pics I found were either of the module removed from its natural habitat or of the ICV.
    Dec 2005
    No e30s, again :(
    hmm, how about google for e30 m42 dme location, or ecu location? see if those pics would also happen to capture what you are looking for?
    [img]http://i1279.photobucket.com/albums/...ps4gexuwzq.jpg[/img]
    is it in that pic. you are right, its hard to find a shot of that area in google
    No e30s again.
    Jul 2012
    Batavia, Ohio
    1988 BMW 325ic
    Was this ICM ever found, and if so, where is it?
    I have a 1988 325i and have been having these random idle surges on a cold start. ICV (not to be confused with the ICM) was replaced a few years ago. Also got a code 16, if that helps.
    Thanks.
    Dec 2005
    No e30s, again :(
    On the 325i, its controlled by the ecu. No idle module
    No e30s again.
    Jul 2012
    Batavia, Ohio
    1988 BMW 325ic
    Thanks, superj.
    Any suggestions then for a code 16? I did replace the idle stabilization relay and cleared codes early this week, but this morning got a brief surging idle. Will have to check for new codes over the weekend. Did hear the ICV buzzing when the key was on and I was checking for codes, just so you know.
    Dec 2005
    No e30s, again :(
    No, no idea
    No e30s again.
  1. Idle control module
    By Galicianslash in forum 1983 - 1991 (E30)
    Last Post: 05-09-2007, 01:08 AM
  2. Idle Control Valve HELP
    By Philly 318i in forum 1991 - 1999 (E36)
    Last Post: 10-11-2006, 12:02 AM
  3. check control module????? help
    By zed///M in forum 1991 - 1999 (E36)
    Last Post: 05-21-2005, 04:40 PM
  4. Idle control module
    By Llewelyn in forum 1983 - 1991 (E30)
    Last Post: 07-14-2004, 04:36 PM
  5. E30 mods changes + Idle control valve help
    By Bernanke in forum 1983 - 1991 (E30)
    Last Post: 11-20-2002, 01:44 AM
