Results 1 to 2 of 2
Thread: Constant voltage regulator???
    San Francisco, CA
    1972 3.0 CSi-1988 M6
    Just bought the oe BMW voltage regulator (12311735742) for the 1991 850. This regulator has a ceramic guide pin on the back, whereas other (most) Bosch regulators don’t. According to the workshop manual, this is a constant voltage regulator (‘mechanically encoded’) and must never be interchanged with other non-coded regulators. What is the difference and what does the ‘constant voltage regulator’ do. Thanks!
    Bert
    91 850i-A
    1972 3.5 CSi (L-jet, Getrag 265 5 speed)
    1988 ///M6
    2021 X3 M40i
    The back to back BIG COUPE” duo
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I asked the electronic expert from the E32 forum, reply from E32Fan: I ran across this issue recently. I have two used alternators, both from 735iL M30 engines. One alternator/regulator (1197311038) has the porcelain "pin", and the other does not.
    I checked the Bosch description in "AUTOMOTIVE ELECTRIC/ELECTRONIC SYSTEMS" 1995 edition, and it does not mention "constant voltage" alternators. But every alternator maintains a constant voltage - that's the whole idea!
    The workshop manual warns: "The constant voltage regulator must never be installed in vehicles whose battery is in the engine compartment. This would result in damage to the battery." So Bosch sees a difference when the battery is in the engine compartment close to the alternator, or far away under the rear seat or trunk. Bosch designed the "pin" for a purpose and it should be respected in maintenance. My guess is that either type will work fine when the battery is remote. You can buy boosted (14.3 volt) regulators, I learned.
  1. Voltage Regulator, Battery, or ?
    By MrAdventure in forum 1983 - 1991 (E30)
    Last Post: 01-23-2004, 05:45 PM
  2. Voltage Regulator location ??
    By Firefighter in forum 1992 - 1999 M3 (E36)
    Last Post: 04-18-2003, 04:09 AM
  3. how hard to replace voltage regulator
    By FLiPModE in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-16-2003, 05:13 AM
  4. 1997 750il, battery, voltage regulator, or alternator?
    By pfiorello in forum 1995 - 2001 (E38)
    Last Post: 07-18-2002, 03:53 PM
  5. Voltage regulator?
    By 318Shawn in forum 1991 - 1999 (E36)
    Last Post: 12-30-2001, 03:26 PM
