Results 1 to 9 of 9
Thread: Additional alternator Q
    San Francisco, CA
    1972 3.0 CSi-1988 M6
    I’m considering adding the additional alternator on my 1991 850. Is the instrument cluster 2nd charging idiot bulb socket wired for operation already for the coupes that we’re not equipped (USA) originally?
    Bert
    91 850i-A
    1972 3.5 CSi (L-jet, Getrag 265 5 speed)
    1988 ///M6
    2021 X3 M40i
    The back to back BIG COUPE” duo
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I have seen it on some M70 in E32, others do not have it, check for this cable http://www.nationalmedia.biz/images/...fyThisWire.jpg
    Oct 2008
    Mt. Dora, Florida
    CSi#18, Tesla S85
    I had the second alternator on my first Alpina. To be honest, unless you are stuck in traffic ALOT, it may not be of use to put it in. That was what they were made for, and why many of the Alpina cars sent to Japan had it.
    CSi #18 - Car & Driver Magazine 1994 actual test car
    -- Hellrot/Black-Gray (1 of 1 NA CSi color combination)
    BMWCCA E31 Chapter International Clubs Liaison
    North America Representative, 8er.or Board of Directors
    San Francisco, CA
    The current charging system (Bosch rebuilt alternator and 2 Bosch AGM H8 batteries) is undercharging, 13.25-13.50 volts max with engine running. Voltage is not affected by engine rpm, either at idle or high rpm operation. Let’s see if the new BMW oe voltage regulator will resolve this charging issue.
    Bert
    91 850i-A
    1988 ///M6
    2021 X3 M40i
    Jan 2005
    Japan
    Better replace the cable between B+ and alternator, after replacing the old rotten thing I got 0.5V more than before. After +20 years of continuous service the insulation has failed. While there is some argument that engine fires have been caused by shorts through the cable tube to ground, one problem that cannot be ignored is that the fine cable strands become badly corroded. Corrosion → higher resistance → higher current drop across the cable → higher temperatures → cable fuses. The battery also does not get the full voltage.
    http://twrite.org/shogunnew/files/ch...20failure1.jpg
    San Francisco, CA
    Installed a new aftermarket B+ cable about 3 years ago.
    Bert
    91 850i-A
    1988 ///M6
    2021 X3 M40i
    Nov 2008
    Maryland
    not enough
    Bert, are you aware that the pulley on your AC compressor needs to be changed to one that has an extra groove for the Aux Alt belt?
    CB42366 - 1991 850i 6-speed. Brilliantrot & Black Nappa Leather
    CD00144 - 1994 850CSi. Hellrot & Black Nappa Leather
    My other projects:
    Supercharged Tbirds, V8 Tbirds, V8 Mustang Convertible, Audi V8 Quattro & Audi S8
    San Francisco, CA
    I did not know this important fact. This really complicates things, probably will end up shelving this project. Thanks for the info!
    Bert
    91 850i-A
    1988 ///M6
    2021 X3 M40i
    Nov 2008
    Maryland
    not enough
    Quote Originally Posted by M6csi View Post
    I don't blame you. I actually have a brand new Aux alternator but have never worked towards getting it installed for that same reason. I don't feel like fiddling with the AC compressor just yet. Maybe when that does need replacement, I'll do the pulley and aux alt. If you ever need the parts just enter a EURO vin # in bmwfans.info and you'll see the part and part #'s.
    My other projects:
  1. Installing an additional window to alternate between tint/clear
    By BimmerBunker in forum 1988 - 1996 (E34)
    Last Post: 05-18-2017, 12:41 PM
  2. DIY: Additional info on E46 alternator replacement
    By nickxtsui in forum E46 Common Problems and DIY Fixes
    Last Post: 11-13-2016, 06:13 PM
  3. I Think My Alternator Just Died -- Seeking Additional Input
    By peter540 in forum 1996 - 2003 (E39)
    Last Post: 06-10-2016, 10:02 PM
  4. DIY: Additional info on E46 alternator replacement
    By nickxtsui in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-04-2012, 11:53 AM
  5. Fuel Additive Brand?
    By Bimmer_Jimmy in forum 1991 - 1999 (E36)
    Last Post: 03-01-2001, 12:39 PM
