2008 bmw 335i 90k miles
Combustion Misfires cylinder 6 not sure the exact code i dont remember but thats the only problem. In the morning it pulls very well but when it gets warmed up it will start misfireing under load. Around 9 psi. It wont misfire with stock tune but it with stage 1 tune. It did not use to misfire with stage 1 tune. No extra bolt ons no burble just a stage 1 tune.
Replaced plug
Replaced coil
Replaced fuel injector
Coded fuel injector
Tried to Cleaned the valves in cylinder 5 and 6 as best as I could not to good of a job but enough to have fixed the problem if thats what it was.
Checked my hardest for vacuum leaks
Im stumped..
Help Please
Make sure plug gap is set to 0.044 inches.
I did. I also swapped plugs with cylinder 1 and it still misfires cylinder 6
Check the resistance on the dme mosfets that drive your ignition coils.
Is this msd80 or msd81?
I can replace those dme's plug and play.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
That's what the doctor ordered.
