Results 1 to 7 of 7
Thread: E36 325i | maintenance questions: Rotten Jackpoints, oil at dif, what to do?
    May 2018
    Amsterdam (EU)
    325i '92, Polo 6R, XJ6S3
    Hi all,
    Recently I have done a big inspection at the car and that raised some questions. The car doesn't have a licence, and to get it road legal, it will need some work.
    The main points for me are:
    - 4 new shocks/ might go for coiloverset.
    - rust at Jackpoints, probably can get a licence with the Dutch rules of rust, but anyone took care of this? I've seen some topics here. But not super clear to me. What to do with those jack points? Around the box (jack points) it's a lot of corrosion.
    - left rear brakeline over gasoline tank
    - front flexible brakeline
    - diff got thick old layer of oil, what to do with that?
    Verstuurd vanaf mijn SM-G950F met Tapatalk
    Apr 2014
    UK
    1995 BMW 328
    1. Remove back seat base, remove access covers, undo tank straps, this gives enough clearance to do over tank pipes.
    2. Flexi lines, basic job just change and bleed. Seal reservoir with a bag or prop pedal so down 2" to stop losing fluid and getting air in the ABS
    3. Shocks / struts - basic stuff just get a decent make
    4. Oil leaks on diff, check level, replace seals or not. Make sure that rear left shaft is fully inserted
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
    May 2018
    Amsterdam (EU)
    Quote Originally Posted by E36328Coupe View Post
    Reove back seat base, remove access covers, undo tank straps, this gives enough clearance to do over tank pipes.
    Nice, that's less hassle now I know this.
    Apr 2014
    UK
    1995 BMW 328
    Sills, depending how bad, patch the bottoms with 1.3mm or 1.6mm plate or buy pattern coupe sills and cut them up to reduce fabrication time.
    The car has side skirts so if not extensive I would o with cheap thick plate
    Apr 2015
    Tennessee
    1998 BMW 328i
    That rust does not look bad. I have seen much much worse. Run it till it blows!
    washington dc
    Avus Cosmos Calypso!
    go to town with brake cleaner on the diff housing and use a catch pan. I would drain that thing first and see what comes out. Looks really nasty. Might want to replace the fluid 3x within 15km or something. Grind off the rust and weld some plates as others suggested. Seal with good rust proof sealant, then something rubbery/asphalt based.
    May 2018
    Amsterdam (EU)
    Thanks for the posts guys! Appreciated
  1. 2006 325i maintenance questions
    By jpark110 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 10-20-2009, 02:11 AM
  2. e36 325is Alarm question
    By Bimmer14PA in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-10-2007, 12:52 PM
  3. Z3 steering rack on E36 325i - install questions
    By jr1966 in forum 1991 - 1999 (E36)
    Last Post: 05-21-2007, 02:56 AM
  4. e36 325i purchasing question
    By prznmafia in forum 1991 - 1999 (E36)
    Last Post: 04-20-2007, 10:04 PM
  5. I have a e36 325is. which is the best oil?
    By DatBxE36 in forum 1991 - 1999 (E36)
    Last Post: 12-06-2006, 11:50 PM
