New to site & BMW, lots of great info
Found air bag light on, blown fuse, dug through the console and found the connector plug that plugged into the air bag module had some melted terminals. I did some research and found the connector plug part numbers are 61-13-8-364-662 & 61-13-8-364-666. I'm trying to locate the part number for the terminal that goes into the connector. I found 61-13-0-005-197 but it already has a wire attached to it. Anyone know which terminal without wire attached fits into this connector plug?
I have also looked for these and eventually just used the ones with wires and used the BMW recommended butt splice connectors. If it helps, I believe these pins are also the same ones used by the LCM module. At least this is all true for E46 cars which were made at the same time.
Sent from my Pixel 2 using Tapatalk
